> Gauges, will a USDM GT speedo work in an ST?
post Dec 4, 2014 - 6:18 AM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
Basically i just want to know if it will work at all or if it will throw a check engine light or something and totally screw me over with a dead battery?
The 3 digits of my gauge cluster is 003 if that matters.
I honestly have no idea about any of this, just heard some things about mismatched gauge clusters before.
Replies (1 - 7)
post Dec 4, 2014 - 6:27 AM
The_enD
Joined Apr 12, '13
I have GT on my AT, the engine light is on, I removed the bulbs, it reads perfectly otherwise.
This post has been edited by The_enD: Dec 4, 2014 - 6:28 AM
post Dec 4, 2014 - 4:40 PM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
QUOTE (The_enD @ Dec 4, 2014 - 6:27 AM) *
Hmmmm ok thanks my Speedo has a bad capacitor on it. Maybe I can swap the speed sensors on the boards to get past the engine light
post Dec 4, 2014 - 5:01 PM
The_enD
Joined Apr 12, '13
I have a bunch of clusters, maybe you can show me yours and I'll show you mine, then you can decide if it's of any use for you. I'll let it go pretty cheap.
post Dec 4, 2014 - 5:36 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (The_enD @ Dec 4, 2014 - 4:01 PM) *
2001 Miata LS 5-speed
post Dec 4, 2014 - 8:08 PM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
QUOTE (Box @ Dec 4, 2014 - 6:36 PM) *
Well someone was bound to point that out. I'll pm you later today when I get home the_end
post Dec 4, 2014 - 10:07 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (Noahwhite2014 @ Dec 4, 2014 - 4:40 PM) *
You should just be able to swap out that individual section of the gauge. There's 3 different sections in the whole thing so you only need to replace the middle one. Once you get the clear plastic and the trim off, just unscrew it from the circuit board side and it'll come out. Then flip that process to put it back in.
post Dec 5, 2014 - 7:13 AM
The_enD
Joined Apr 12, '13
QUOTE (mkernz22 @ Dec 5, 2014 - 5:07 AM) *
That is true. But the green board on the back can also differ. I don't know how that will affect the internal parts's connections.
Lo-Fi Version Time is now: August 28th, 2026 - 10:10 AM
