> Random 3 wire connector BEAMS
post Dec 10, 2014 - 12:40 PM
Rooster92
Joined May 8, '14
From Houston
I have a connector i don't have plugged into anything, i'm thinking maybe that's why i can't get my speedo to work. it has 3 wires in it, they are red/blue middle wire is blue/black and the left wire is blue.
It is located near my MAF and under the throttle body. The engine i have is a 3sge redtop. Anyone know what my unidentified connector might be?
Thanks
-Chris
post Dec 10, 2014 - 1:15 PM
richee3
Joined Jun 29, '08
From Denver
There's s three wire plug on top of the trans for the speedo. It's a little difficult to find without taking things aboart but you should be able to find it if you feel around.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Dec 10, 2014 - 1:27 PM
Rooster92
Joined May 8, '14
From Houston
QUOTE (richee3 @ Dec 10, 2014 - 2:15 PM) *
any particular part of the trans?
nvm, on top... hmm
post Dec 10, 2014 - 1:32 PM
Rooster92
Joined May 8, '14
From Houston
What would you take apart to make it easier to see? everything is plugged in that i can see, ive gone over it multiple times.
post Dec 10, 2014 - 1:39 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
id think that taking off the intake piping would give you a clearer view of the top of the trans
エキサイティングカーレーシングチーム!
post Dec 10, 2014 - 1:42 PM
Rooster92
Joined May 8, '14
From Houston
Yeah i've taken off the intake.
post Dec 10, 2014 - 1:50 PM
richee3
Joined Jun 29, '08
From Denver
It's towards the firewall side of the trans. It's not easy to see with the engine in the bay, unless you take the intake plenum off and even then it's not the easiest to find. You can feel around for it until you find it though. Still not easy but it's the easiest way to find it. There are two plugs on the trans, one is for reverse lights and the other is for the speedo. You should be able to find it in a couple of minutes by feeling around. It's somewhere in the area directly underneath the throttle body.
1998 Celica GT-
BEAMS Swapped.
post Dec 10, 2014 - 1:57 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
The connector is almost directly above the input shaft of the passenger side axel, if you were to go straight up from the axel on the transmission - still, not the easiest thing to get to.
post Dec 10, 2014 - 4:09 PM
Rooster92
Joined May 8, '14
From Houston
Thanks guys i just got from the junk yard. Im about to pilfer under there. Ill report back.
post Dec 10, 2014 - 4:32 PM
Rooster92
Joined May 8, '14
From Houston
It worked, thanks you both, Khaos that was an excellent explanation. let me right to it.
-Chris
Lo-Fi Version Time is now: August 21st, 2026 - 11:34 PM
