Dec 10, 2014 - 4:03 PM
Sammy Hagar references out of the way I figured I should do a project thread for my newly acquired Firebird. Since I already posted pictures in the Today I... thread I'll just post the one plus one of the engine for the time being.
![]() ![]() For those that didn't see in the other thread it has a 4-bolt main 350 and TH-350 from a '69 Chevelle. The 350 has been bored .40 over, heads worked and shaved for 12:1 compression ratio, 3/4 cam, and Edelbrock 750cfm carburetor & intake. The transmission was also gone through and refreshed as well. The car also has new brakes and suspension, for whatever that's worth. As far as plans I'd like to finish up the exterior and interior as I go. Then engine is sorted as far as I'm concerned, just needs some headers and a full exhaust done along with a new air cleaner setup as you can see. Oh, and hook up A/C again. I'll just get a compressor and brackets from a same year Camaro. Would like to upgrade the brakes and suspension along with converting to a manual one of these days. This will be a car I intend to keep for pretty much forever as I've always wanted one and it was/is one of my realistic dream cars, along with the Corvette. In the coming days I'll be touching up a few things here and there not really worth writing about, i.e. replacing bulbs and wipers etc... -------------------- 2001 Miata LS 5-speed
Dec 10, 2014 - 7:55 PM
Disc brakes?
Dec 10, 2014 - 10:53 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 3, '13 From Missourah Currently Offline Reputation: 0 (0%) |
Looks like ya need some headlight adjuster screws/hardware, that way Boss Hog won't pull ya over on the way back from where your still is hidden.
-------------------- Bust a Deal; Face the Wheel.
Dec 10, 2014 - 11:05 PM
I hate those wiper/washer setups on those. Frickin diaphragm pump built into a cam on the wiper motor and damn if they ever work quite right. Plumb in a little inline pump instead or something if you want reliable working washers.
http://www.nastyz28.com/tech/electrical/wiper.html This post has been edited by Bitter: Dec 10, 2014 - 11:10 PM -------------------- |
Dec 11, 2014 - 11:03 AM
that car needs a 2jz or a 3sge blacktop, real bad.
Dec 11, 2014 - 1:35 PM
Looks like ya need some headlight adjuster screws/hardware, that way Boss Hog won't pull ya over on the way back from where your still is hidden. I have some. On that one the plastic insert slipped and now it's going to be a pain to remove it to put in the new one. Figured might as well wait until I'm putting in new and improved headlamps to mess with it. -------------------- 2001 Miata LS 5-speed
Dec 11, 2014 - 1:42 PM
Disc brakes? In the front. I hate those wiper/washer setups on those. Frickin diaphragm pump built into a cam on the wiper motor and damn if they ever work quite right. Plumb in a little inline pump instead or something if you want reliable working washers. http://www.nastyz28.com/tech/electrical/wiper.html All of the stuff is there and the interior controls work, just missing the bottle. Thanks for the link, I'll have to check it out. I'm sure the pump died which would explain the missing bottle. -------------------- 2001 Miata LS 5-speed
Dec 11, 2014 - 2:09 PM
that car needs a 2jz or a 3sge blacktop, real bad. Those don't sound like Satan laughing or violently twist the body when you rev them up, where's the fun in that? Also, I've never had so many people stop to look/ask about a car... I've already lost count, not to mention the people that turn and look as you drive by. I guess if I was wanting a low profile car I chose the wrong one. Anyhow, almost done going through and checking everything and will be placing an order at RockAuto soon. I found some Wagner sealed beams that're supposed to be brighter/whiter than conventional halogen for $5-8 each. Not bad and will hold me over until I can decide on a more advanced optics. I also found some electronic flashers I think I'll buy since they'd allow me to use LED bulbs for all of the signal lights. Still have to decide on if I want to go with long tubes or shorties as well as work out a better air cleaner setup. The amount of options is staggering, which does make for a nice change for once. -------------------- 2001 Miata LS 5-speed
Dec 11, 2014 - 6:35 PM
Was able to get the rear window trim in and got to the point where I can put new bulbs in the driver taillight, then ran out of light. The bulbs have been in there for a long time apparently as they're seized into the sockets...so of course a ten minute job is taking over an hour... So will finish it and then do the passenger side tomorrow. Need to get onto RockAuto and start a list of parts to buy. It never ceases to amaze me how content someone can be with a car, then I get a hold of it and kill myself trying to fix every little thing.
Dec 11, 2014 - 8:01 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 5, '09 From West Texas, USA Currently Offline Reputation: 20 (100%) |
It would look good with some of those reproduction snowflake wheels.
Dec 11, 2014 - 8:29 PM
I really love the snowflakes, just not sure if I'd want to go up to 17's though. Currently it has Rally II rims, and finding a set of original snowflakes wouldn't be too pricey. Either that or get the 16" GTA rims from the third gen. Like I said earlier, lots of choices... Being the world's most indecisive person doesn't help.
Dec 11, 2014 - 8:42 PM
Hey at least you have a car now
Dec 11, 2014 - 9:31 PM
As far as lights, Cibie Z beams if you want to keep with classic halogens, I think they come in 4x6 rectangles (I think that's what you have).
Otherwise buy some plastic housings with clear front lenses and go crazy with some sweet D2S Bixenon projectors backed by some good OEM ballasts and very bright Nightbreaker Unlimited D2S bulbs and you'll have some awesome lights. You can do some Halo's packed behind the shrouds or out in front or some nice demon eyes. Use amber halo's and tie them into the turn signals, all kinds of ideas. -------------------- |
Dec 11, 2014 - 11:52 PM
totally need louvers on the back window.
Dec 12, 2014 - 12:33 AM
Hey at least you have a car now Exactly, I'm sure everyone I knew was tired of giving me rides all of the time. -------------------- 2001 Miata LS 5-speed
Dec 12, 2014 - 1:01 AM
As far as lights, Cibie Z beams if you want to keep with classic halogens, I think they come in 4x6 rectangles (I think that's what you have). Otherwise buy some plastic housings with clear front lenses and go crazy with some sweet D2S Bixenon projectors backed by some good OEM ballasts and very bright Nightbreaker Unlimited D2S bulbs and you'll have some awesome lights. You can do some Halo's packed behind the shrouds or out in front or some nice demon eyes. Use amber halo's and tie them into the turn signals, all kinds of ideas. I'd only want to do HID's if I go pretty far with the resto-modding. That and my brother with 5K HID's constantly gets flashed and he has projectors with a nice cutoff that're aimed properly... I have really sensitive eyes and constantly getting flashed would not be good. totally need louvers on the back window. Yes!!! -------------------- 2001 Miata LS 5-speed
Dec 12, 2014 - 8:18 AM
If he's always getting flashed then they're not aimed right or people down there are as stupid as the stereotypes.
Or did he shove HID's in halogen projectors? If he did then that's why he's getting flashed all the time, halogen projectors usually glare pretty bad with HID's installed since the arc isn't a bulb filament the lens and bowl are not tuned for HID. Also there's usually holes in the cutoff to allow some light above the cutoff to illuminate signs, HID projectors don't have that. This post has been edited by Bitter: Dec 12, 2014 - 8:33 AM -------------------- |
Dec 12, 2014 - 10:28 AM
Gripping the wheel, his knuckles
went white with desire! The wheels of his Mustang exploding on the highway like a slug from a .45. True death: 400 horsepower of maximum performance piercing the night... This is black sunshine -------------------- Bust a Deal; Face the Wheel.
Dec 12, 2014 - 10:43 AM
Hey at least you have a car now Exactly, I'm sure everyone I knew was tired of giving me rides all of the time. ****, when you're always asking for rides people stop answering the phone quick. And "hey can I borrow your car." Is even worse than "Hey can I borrow your wife?" -------------------- Bust a Deal; Face the Wheel.
Dec 12, 2014 - 1:57 PM
If he's always getting flashed then they're not aimed right or people down there are as stupid as the stereotypes. Or did he shove HID's in halogen projectors? If he did then that's why he's getting flashed all the time, halogen projectors usually glare pretty bad with HID's installed since the arc isn't a bulb filament the lens and bowl are not tuned for HID. Also there's usually holes in the cutoff to allow some light above the cutoff to illuminate signs, HID projectors don't have that. We did it from 20' and they're set to where the focus point hits 30" off the ground. I think it's a lot of stupid people, because we even drove towards each other to double check and there wasn't any excessive glare and they're about as white as you can get. What killed me is there was some tool in a lifted truck with eBay 10K HID's in reflector housings that had the audacity to try and start ****. I'm like really? I have to wear yellow lenses at night unless I want to be blinded constantly. I really need to get a doctor to write me an exemption so I can run darker window tint than what's legally allowed. I've thought about running a sheet of 70-90% across the entire windshield to cut glare and UV down, then have the 6" strip of 2.5% I think the exemption allows me to run at least 20% on the sides and back versus the 35% that's normally allowed. -------------------- 2001 Miata LS 5-speed
| Lo-Fi Version | Time is now: August 23rd, 2026 - 7:52 AM |
