Feb 10, 2004 - 5:23 PM
well im in the process of putting on my turbo. right now everything is stock. like the fuel pump which will be changed later on when the turbo is actullay on. ok so heress the deal. i put in the new 315cc injectos light green tops or whatever the same ohm independency. and i regapped my plugs to .030 all trac spec. the car wont run for more than like 1 secound lol. whats the problem? every thing is stock except the injectors and gap setting. help.
x_itchy_b_x help car wont run. since i put in 315cc injectors Feb 10, 2004 - 5:23 PM
Supersprynt are the injectors clogged? Feb 10, 2004 - 6:16 PM
slipgun Talk to 97sccelica, he waited to put on the new fu... Feb 10, 2004 - 6:36 PM
macavely you have to check which one your missing spark,ful... Feb 10, 2004 - 6:48 PM
x_itchy_b_x QUOTE (slipgun @ Feb 10, 2004 - 7:36 PM) Talk to 9... Feb 10, 2004 - 7:05 PM
SpedToe169 I doubt it will run if you don't do anything e... Feb 10, 2004 - 7:56 PM
x_itchy_b_x QUOTE (SpedToe169 @ Feb 10, 2004 - 8:56 PM) I doub... Feb 10, 2004 - 8:02 PM
toyotaspeed_90 i would say do a quick check and toss the old inje... Feb 11, 2004 - 12:56 AM
SpedToe169 QUOTE i was told i dont have enuf pressure. and th... Feb 11, 2004 - 2:16 PM
97sccelica your probably running really rich like speedtoe sa... Feb 11, 2004 - 2:50 PM
capncrakhed this same thing happened to me
the engine wasnt r... Feb 11, 2004 - 4:22 PM
SpedToe169 QUOTE this same thing happened to me
the engine w... Feb 11, 2004 - 4:59 PM
x_itchy_b_x QUOTE (SpedToe169 @ Feb 11, 2004 - 3:16 PM) QUOTE ... Feb 11, 2004 - 8:13 PM
capncrakhed you dont need a 2 bar map for it to run.....it is ... Feb 11, 2004 - 8:19 PM
x_itchy_b_x QUOTE (capncrakhed @ Feb 11, 2004 - 9:19 PM) you d... Feb 11, 2004 - 8:22 PM
JWalk1818 You can also use like 3 check valves in your map s... Feb 19, 2004 - 10:19 AM
x_itchy_b_x QUOTE (x_itchy_b_x @ Feb 11, 2004 - 9:22 PM) QUOTE... Feb 19, 2004 - 11:00 AM![]() ![]() |
| Lo-Fi Version | Time is now: September 13th, 2026 - 6:37 PM |
