> eBay Header, See Link
post Dec 21, 2014 - 9:45 PM
msk59
Joined May 10, '14
From Tulsa, OK
Are these any good? Appreciate your input.
http://www.ebay.com/itm/Toyota-Corolla-Cel...52c&vxp=mtr
post Dec 22, 2014 - 12:44 AM
igpx12
Joined Jan 30, '14
From Cortland NY
QUOTE (msk59 @ Dec 21, 2014 - 10:45 PM) *
That looks like my 4-2-1 header that I had ceramic coated. The only real considerations to make with a header is the clearance you have between the oil filter and header, obviously you want to be able to do an oil change. With mine I have 1-1.5 inches space between the header and filter. The other consideration in regards to space is getting the header either ceramic coated or wrapped to prevent overheating of underhood components such as your oil filter. I went with a ceramic coating mainly because it evenly coats it and its in a section on the exhaust system that doesn't see a lot of debris. One upside that I really did like was that the O2 sensor mounts to a flange which is then bolted onto the header unlike the stock system where the sensor mounts into a bung of course this is only really good if you need to check your sensor to see if the engine is running rich or lean or if you have to replace the header. Look at some other 7AFE owners on here and see what they have done, from what I've seen this is a popular upgrade basically because the 7AFE doesn't have much in the sense of performance parts on the market.
This post has been edited by igpx12: Dec 22, 2014 - 1:51 AM
1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool.
post Dec 22, 2014 - 9:31 AM
cheela
Joined Feb 2, '07
From Berlin, WI
Here's mine installed and wrapped. gives it a decent sound and a little bit more umph at the upper end.
and yeah, this is pretty much the only header that will work for the ST. sad that the corolla has more support than the celica. laugh.gif
but you will have to add an inch or two to the piping. there's a sticky for it on the forums here.
post Dec 22, 2014 - 11:24 AM
msk59
Joined May 10, '14
From Tulsa, OK
Thanks guys! much appreicated. Cheela what do you mean by, "but you will have to add an inch or two to the piping" Are you suggesting that when you installed this header, the other end of the header which connects to the pipe will have a gap that I need to fix?
I have a oil cooler mod done (I posted in this section with pcitures) So with that my oil filter protrude outward about an inch since I installed a sandwich adapter (one inch thick). So with out test fitting this header with purchasing it, there is no way for me to find out whether it will fit or not. (if it did not then I have to either reloate the filter or think of something else.
I will check other threads as well.
post Dec 22, 2014 - 2:01 PM
cheela
Joined Feb 2, '07
From Berlin, WI
pmd u
Lo-Fi Version Time is now: August 26th, 2026 - 12:30 PM
