> FS: GEN4 Downpipe w/catalytic converter *PLUG AND PLAY*
post Dec 31, 2014 - 12:04 PM
MR2fanatic
Joined Jul 21, '10
From Northern NJ
For everyone who is looking for an emissions compliant bolt-in catalytic converter, we have a solution for you! Made in house at Prime, we offer our 3" Downpipe w/ Integrated Catalytic Converter. We cut the top off the stock Gen4 cat converter and weld on 3" tubing and a magnaflow catalytic converter . This is a direct bolt on for a Gen4 or Gen5 powered MR2 with any MR2 turbo exhaust system! This 3" downpipe clears the A/C compressor.
* Quality and fitment that you've come to expect from PRIME PERFORMANCE! Proudly 100% MADE IN THE USA! *
Does not come with hardware, gaskets, or support bracket.
SPECS:
These MagnaFlow universal spun catalytic converters utilize the revolutionary new catalyst technology. Using new manufacturing technology, MagnaFlow fabricates each converter body from a single CNC-formed and laser-welded tubular section, which is then spun into a round converter body shape. The MagnaFlow universal spun catalytic converters are literally manufactured around the catalyst, which is securely tucked inside and necks down to thicker-gauge material at the inlet/oulet for maximum durability.
AIR Tube: No
California Legal: No
Converter Case Material: Stainless steel
Converter Substrate Material: Metallic substrate
Heat Shield: No
Converter Style: 3-way
Buy it here: http://www.primemr2.com/store/c9/GEN4_GO-FAST_Parts%21.html
PRIME Performance 862-258-3346
Check out our store and services: www.PRIMEMR2.com
Lo-Fi Version Time is now: August 31st, 2026 - 4:29 AM
