Jan 6, 2015 - 2:50 PM
Enthusiast Joined Jan 6, '15 From Quebec Currently Offline Reputation: 0 (0%) |
Hi, my g/f has a 6g celica GT and she would like to have all 4 lights on at night (daytime and night time (not high beams)). Can we just add a jumper wire? If so, from where to where? Thanks.
Jan 7, 2015 - 10:05 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
If you want to blind everyone, yes.
Or, you could just drive with your highbeams switched on, but once again, that will blind everyone. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Jan 10, 2015 - 11:35 AM
Jan 11, 2015 - 8:10 AM
Enthusiast ![]() ![]() Joined Jul 1, '14 From Hawaii Currently Offline Reputation: 3 (100%) |
The DRLs seem so weak thought... How could they blind? If you want to blind everyone, yes. Or, you could just drive with your highbeams switched on, but once again, that will blind everyone. He said highbeams switched on all the time. The high beans are aimed upward so they will always blind people because they aren't aimed at the road like low beams. and they are also higher wattage bulbs. If you jump the wire from the lowbeam power to the highbeam power you will probably blow a fuse. If you jump the Fuse you will probably burn wires. The only thing I can think of doing in your case is removing the bulb and finding the same size bulb but really dim. Just enough so it lights up the housing, but doesn't really shine far and into people's eyeballs as they drive toward you. |
Jan 12, 2015 - 9:24 AM
Or if you want just the look of 4 headlights lit up, and not the light output, you could somehow install LEDs in the housing to light it up, and wire it into you switched driving lights somehow, to light up the inside headlight housings.
Otherwise, I don't think this is a great idea. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Jan 12, 2015 - 5:40 PM
![]() Enthusiast ![]() ![]() Joined Apr 21, '13 From YYC Currently Offline Reputation: 1 (100%) |
Please tell your GF not to do this.
Jan 12, 2015 - 9:31 PM
Also I forgot to mention, our "DRLs" are just the turn signals dimly lit (this is just for the front DRLs and this is one turn back on the light switch stalk). The two outer lights are our headlights (two turns back) . And the two inner lights are our high beams (pull the stalk back).
The LEDs in the housing isn't too bad of an idea, but without some knowledge about reflectors and refraction you're going to be just guessing and checking. Especially since LEDs have directional light output |
Jan 14, 2015 - 2:27 PM
Enthusiast ![]() Joined May 13, '12 From US- NY Currently Offline Reputation: 9 (100%) |
You can possibly look for Bi-Xenon HID lights that would fit in the high beam casing. Some cars which only use one bulb which works for their lows and highs use these. Here is a better explanation on how they work. https://www.youtube.com/watch?v=QSq3tjhKzDs
Jan 14, 2015 - 7:42 PM
You can possibly look for Bi-Xenon HID lights that would fit in the high beam casing. Some cars which only use one bulb which works for their lows and highs use these. Here is a better explanation on how they work. https://www.youtube.com/watch?v=QSq3tjhKzDs Yeah but he would have to pay around $150 for a projector retrofit kit and 100 for decent ballasts and bulbs and buy a set of Jdm clear high beams. Then wire it all up. It would probably be easier to just buy led projector bulbs and replace the high beams with them, and aim them properly |
Jan 24, 2015 - 11:12 PM
Enthusiast ![]() ![]() Joined Jan 30, '14 From Cortland NY Currently Offline Reputation: 5 (100%) |
Honestly if you'd consider running all 4 lights without having to bother with the cutoff or reflectors, you'd have to see about a retrofit kit. Of course you'd have to sand down the inside of your headlight lenses to make them clear as well as treat them with a UV protectant so they don't yellow out or haze up and also if you want them to look decent on the inside see about making bezels for the projectors. That aside, a basic retro fit kit that has everything you need would be 270.00 as seen on here:
http://www.theretrofitsource.com/complete-...ml#.VMRs4vDtvGs Seriously though, talk her out of it and if you guys feel like going more modern with the lights, put the hundreds of dollars that this would cost and get JDM clear projector headlights -------------------- 1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool. |
| Lo-Fi Version | Time is now: July 29th, 2026 - 10:09 PM |
