> Alternator problem ?
post Jan 11, 2015 - 2:24 PM
CrossCudi
Joined Mar 10, '11
From New Jersey
so yesterday on my way home from work, my battery light went on.
just a little while longer my headlights went off as I felt my car losing power.
eventually my car died and had it towed to my house.
this morning I decided to look into it and noticed a burning smell from the alternator.
so I disconnected it and found this :
I took the alternator to test and its fine.
I bought a new battery and still no juice. seems like I might have a short somewhere but I don't know where to start ..
any ideas ?
thanks .
94' Celica GT Manual
Replies (1 - 5)
post Jan 11, 2015 - 3:24 PM
silverceli
Joined Nov 10, '13
From nj
I can almost guarantee that u blew the fusible link it's a 100 amp fuse in the fuse box under the hood just an FYI it doesn't pull out it bolts in so u have to remove the fuse panel from the plastic cover it's real easy tho just a couple of plastic tabs that need to be pushed out..and it should b problem solved
post Jan 11, 2015 - 3:36 PM
mi645
Joined May 23, '12
From northridge,CA
the harness . the 12 that connects to the alternator, that terminal u have in the picture, plug in the battery in the car, grab a volt meter and put the power to that terminal and the ground to the car, and see if the bytery voltage is actually reaching to that wire which goes to the alternator
post Jan 11, 2015 - 3:51 PM
Box
Joined Feb 23, '12
From Warrior, AL
When they tested the alternator did they only test that it output power or what it output as well? If there was a burning smell it could've been the internal voltage regulator.
2001 Miata LS 5-speed
post Jan 22, 2015 - 1:33 AM
CrossCudi
Joined Mar 10, '11
From New Jersey
QUOTE (Box @ Jan 11, 2015 - 4:51 PM) *
you were absolutely right ! I took the alternator to another location for testing and that was the problem. so went back for a new one and car is up and running great !
post Jan 22, 2015 - 1:50 AM
Box
Joined Feb 23, '12
From Warrior, AL
Wooo, I'm on a hot streak! tongue.gif Glad it was a simple enough fix.
Lo-Fi Version Time is now: July 9th, 2026 - 10:21 AM
