> S54 Transmission dead?, need help identifying problem
post Feb 12, 2015 - 1:49 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
Hi all, I wanted to get as much feedback as possible before I replace or rebuild my Transmission.
As it is well known, 3rd gear is notorious for grinding in the GT transmission. mine grinded for sometime but only if I accelerated hard.
One day I was driving normally and chose to pass a slower vehicle in front of me. what happened next completely confuses me.
when shifting down from 4th to 3rd I got NO response, it was as if the car was in neutral. I tried each and every other gear to find that no gear worked (motor revved but no response)
Upon further inspection I noticed that the speedometer still worked while the car was in gear (when car was jacked up and on ground) I also noticed a SLIGHT grinding noise while the car was in gear as if a moving part was spinning and barely touching metal.
I figured my axles were bad, so I jacked the car up again, and slowed down the drivers side wheel to see if my RPM changed any (it did not)
I noticed that only one wheel would spin, and the passenger side would not. When I tried again (using an old deflated basketball to slow the tire) the basketball got sucked under the wheel, and got stuck causing the passenger side axle boot to tear off, and my axle to pop out of the hub. (this tells me that the axle was attempting to spin)
I was told by a friend that my differential is blown. do any of you know this to be true? any help would be appreciated. Thanks!
This post has been edited by easternpiro1: Feb 12, 2015 - 1:50 PM
- easternpiro1   S54 Transmission dead?   Feb 12, 2015 - 1:49 PM
- - ILoveMySilly97   Sounds like a bad axle to me. Did you check to see...   Feb 12, 2015 - 1:56 PM
- - VavAlephVav   You may have bad axles also, but that wouldn't...   Feb 12, 2015 - 2:11 PM
- - easternpiro1   Yeah the trans has some miles on it. Was hoping it...   Feb 13, 2015 - 9:03 AM
- - perkyshadow   Hawk Pull-a-part for a while. You may be able to f...   Feb 13, 2015 - 9:51 AM
- - Marsstar505   Sounds like either the cv axle or wheel bearing on...   Feb 13, 2015 - 10:43 AM
- - VavAlephVav   It may work well enough to drive it for several mo...   Feb 13, 2015 - 11:18 AM
- - SupraKid   Axle...popped out...of the hub? Doyouevenaxlenutbr...   Feb 13, 2015 - 1:00 PM
- - ILoveMySilly97   I have a buddy from California who has a s54 that ...   Feb 13, 2015 - 1:30 PM
- - easternpiro1   thanks vav i pm'd him but I doubt he will as i...   Feb 13, 2015 - 2:35 PM
- - easternpiro1   Update: finally got around to messing with the car...   Apr 22, 2015 - 12:39 PM
- - Box   Perfect excuse for swapping in a LSD.   Apr 22, 2015 - 3:51 PM
- - easternpiro1   true! BUT LSD=SUPER expensive and syncros goin...   Apr 23, 2015 - 7:15 PM
- - Box   Awwww, ok. I second trying to find an E153 thoug...   Apr 23, 2015 - 7:51 PM
- - Smaay   LSD wont make syncros go bad. has nothing to do w...   Apr 23, 2015 - 10:09 PM
|- - enderswift   QUOTE (Smaay @ Apr 23, 2015 - 11:09 ...   Apr 23, 2015 - 10:23 PM
- - Box   I think he meant since his synchros are going out ...   Apr 23, 2015 - 10:22 PM
- - bsamps4   Matt, I'm currently exploring the option of p...   Apr 24, 2015 - 1:33 PM
- - easternpiro1   Thanks fellas, Box is right I wouldn't get a ...   Apr 25, 2015 - 12:19 PM
- - Box   Oooh, just had a flashback to when my brother rebu...   Apr 25, 2015 - 1:54 PM
Lo-Fi Version Time is now: September 15th, 2026 - 12:10 AM
