> Suspension Travel when jacking car up
post Feb 15, 2015 - 7:16 AM
chica8398
Joined Jun 20, '14
From United Kingdom
Hi All
The other day i had to jack the car up to change the front wheel, i noticed that the rear tyre was off the ground way BEFORE the front.
Yes i did have the jack at the front jacking point.
When i did the other side of the car this didn't happen.
Does this mean i have a different suspension setup ffrom one side to the other ??
I've only had the car a short while so don't know it's maintenance history.
Regards
Chica8398
Replies (1 - 6)
post Feb 15, 2015 - 8:33 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
Do you have Coilovers?
エキサイティングカーレーシングチーム!
post Feb 15, 2015 - 9:41 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
Could have a locked up strut if the suspension is all factory.
post Feb 15, 2015 - 1:55 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Just look at the suspension and you'll know if theyre different. Btw, the front is heavier than the rear so if you jack at a point where its closer to the rear then the rear will go up first.
post Feb 15, 2015 - 4:49 PM
chica8398
Joined Jun 20, '14
From United Kingdom
Thanks for the reply's.
I'll check the struts and do more investigation this weekend.
Appreciate all the help
thanks
post Feb 17, 2015 - 4:54 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
this is normal happens to me as well. unless you have coilovers might be a bit different
post Feb 18, 2015 - 2:43 PM
chica8398
Joined Jun 20, '14
From United Kingdom
QUOTE (BonzaiCelica @ Feb 17, 2015 - 4:54 PM) *
Thanks BonzaiCelica
Put my mind at ease.
Really appreciate ALL the input from everyone
Regards
chica8398
Lo-Fi Version Time is now: June 15th, 2026 - 9:44 AM
