> She's getting old and tired
post Feb 17, 2015 - 5:45 PM
rkelly_83543
Joined Feb 8, '09
From Moscow, ID
So I have a 1994 Celica GT with the 5SFE and 5 speed manual.
A few weeks ago I started to notice a faint raw fuel smell in the cabin while idling.
I put off diagnosing the issue until I could find a little more time to look into it since it wasn't a serious leak.
Now it has started making a ticking noise (louder than normal for a Toyota). Last time I had the oil changed at the dealership (I didn't have time to do it myself) they mentioned metal shavings in the oil.
Today my wife was driving the car on a city street around 25 mph and she decided to blow the plug out of the third cylinder.
I haven't touched the plugs in a few years so why this would happen now is weird.
The contact at the end of the plug was gone too (spark tip).
Is it time to put her out to pasture?
post Feb 17, 2015 - 6:29 PM
Box
Joined Feb 23, '12
From Warrior, AL
Fuel smell and ticking noise probably means an exhaust leak. The plug could've not been tightened down enough and it just backed out over time. If there hasn't been metal in the oil before and there hasn't been any over-revving or running it low on oil, it could just be dealer blowing smoke in order to get you to pay for more work. If the spark plug threads are still good I say it'd be worth the $10 for a new set of plugs and sourcing down what most likely is an exhaust leak.
2001 Miata LS 5-speed
post Feb 17, 2015 - 7:31 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
shavings in the oil is BAD BAD BAD, if its ticking, then your bearings are going and it needs to be fixed now. otherwise the engine will destroy itself.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Feb 17, 2015 - 8:58 PM
rkelly_83543
Joined Feb 8, '09
From Moscow, ID
I pulled the rest of the plugs tonight and they looked pretty worn. Another was missing the electrode. They were the Bosch +2 type that has a very fine electrode. I was also able to turn cyl 4 spark plug by hand so I'm thinking it was fixing to blow as well. It's due for an oil change so I will be looking for these shavings myself to rule out the good old dealership tricks. Thanks for the replies! smile.gif
post Feb 17, 2015 - 9:23 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
The plugs on this thing are so easy to get to I just run copper and change them once a year. /shrug
Bust a Deal; Face the Wheel.
post Feb 17, 2015 - 9:31 PM
Box
Joined Feb 23, '12
From Warrior, AL
You know, versus what it says to run that would last much longer and don't cost that much more anyway. tongue.gif
The Bosch plugs are gimmicky crap, get some NGK G-powers and call it a day.
Lo-Fi Version Time is now: September 14th, 2026 - 10:45 PM
