> A-pillar driver side vibration/noise
post Feb 19, 2015 - 11:43 AM
LtSolid
Joined Jan 9, '15
From Freeport, NY
when ever im accelerating past 3k rpms at a fast past, there would always be a ringing with a vibration on my a-pillar. i was wondering if anyone else has ever experienced this as well.
Replies (1 - 3)
post Feb 19, 2015 - 7:01 PM
igpx12
Joined Jan 30, '14
From Cortland NY
QUOTE (LtSolid @ Feb 19, 2015 - 12:43 PM) *
Cant say that I have with all the clips on the plastic trim secured with the pillar. Sounds like you may have something loose behind your trim.
1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool.
post Feb 19, 2015 - 10:46 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
Or the strut and mount on that side are wasted.
Bust a Deal; Face the Wheel.
post Feb 20, 2015 - 6:20 AM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
QUOTE (LtSolid @ Feb 19, 2015 - 11:43 AM) *
pull the a pillar trim off. its tucked behind the b pillar trim but is pretty flexible so you can slide it out from underneath. Pull downward and then once you have the upper part out, pull straight out from the a pillar. Once you're at the bottom of the a pillar, pull the whole thing upward toward the center of the roof to release the last clip holding it in. Examine all the little metal pieces that are clipped on the plastic on the a pillars, If you see any missing. that noise is the metal piece stuck in the a pillar. I had that issue before, i pulled out a neodymium magnet, Put it all the way toward the bottom of the A pillar, and waited to hear a ping from the metal, Then dragged it upward to the nearest hole and then i pulled it right out.
Good luck!
Lo-Fi Version Time is now: August 25th, 2026 - 12:43 AM
