Feb 26, 2015 - 12:03 AM
Enthusiast Joined Jan 5, '15 From TN,USA Currently Offline Reputation: 0 (0%) |
Greetings again, 1995 1.8L, looking for the location of the fuel filter on the car. Not in the area to look around nor have a manual on hand.
Thanks, Birk |
Feb 26, 2015 - 12:19 AM
Enthusiast ![]() ![]() ![]() Joined Nov 4, '09 From Sacramento, California Currently Offline Reputation: 0 (0%) |
Try this out http://www.6gc.net/forums/index.php?showtopic=68364
-------------------- Brand new 6gc owner! (sort of 2011)
The world is moving around a sun, the sun moves around a local arm of the galaxy, the local arm of the galaxy moves around a gigantic black hole. |
Feb 26, 2015 - 12:52 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
Its on the fuel pump in the tank. Hope your lines aren't rusted otherwise you'll need a new bracket cause they're a pain in the ass to take apart. That or you could drop the tank.
Also, there's an access cover under the rear seat. |
Feb 26, 2015 - 1:49 AM
Generally the one intank is referred to as a strainer or sock, if I had to take a guess he means the one inside the engine bay. Which is near the bottom of the air filter box, just follow the line off the fuel rail and you come across a canister about the size of a soda can. It is a royal pain in the ass to replace, especially if it's never been replaced like most of them.
Feb 26, 2015 - 7:34 PM
Enthusiast ![]() ![]() Joined Jan 30, '14 From Cortland NY Currently Offline Reputation: 5 (100%) |
Like Box said, it can be a royal in the ass. You'd want some line wrenches to fit the fuel lines otherwise you might end up twisting your lines or stripping the nut. But here is the exact location of it in the engine bay with a 1.8L:
-------------------- 1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool. |
| Lo-Fi Version | Time is now: August 27th, 2026 - 6:14 PM |
