> strut going thru mount
post Mar 4, 2015 - 5:44 PM
Jmk91
Joined Jan 25, '15
From United States
So I installed all new KYB g2 struts with KYB mounts and brand new bump stops and sway bar end links and TRD springs. Everything is 100% new and correct parts. What's happening is the rear strut is moving like pushing threw the mount over any bumps causing a clunk sound. The nut in the rear that's in the middle of strut mount has play over any and all bumps. Like my strut isn't done correctly. The strut assembly is moving. I've replaced everything I can think of I also installed everything correctly... Ive had out the rear struts 3 times. Everything is done right I even have everything torqued to spec. So I'm lost... I didn't get an alignment yet but I honestly font want to drive my car way it is to a shop. I don't want to damage anything. Any ideas before I take it to a shop and pay out 3 arms and 2 legs. Any suggestions or ideas or if anyone else has went thru this help is greatly appreciated. Its also only in the rear. Front are fine I did all 4 at once.
- Jmk91   strut going thru mount   Mar 4, 2015 - 5:44 PM
- - Box   That is weird, unless the rear struts are defectiv...   Mar 4, 2015 - 6:22 PM
- - Jmk91   It is weird. I'm clueless. They are 100% new s...   Mar 4, 2015 - 6:28 PM
- - Jmk91   I also changed rim size too If that matters. Went ...   Mar 4, 2015 - 7:37 PM
- - Box   That wouldn't have anything to do with with it...   Mar 4, 2015 - 8:45 PM
- - BonzaiCelica   ya those springs don't drop that low anyway. b...   Mar 5, 2015 - 2:20 PM
- - Jmk91   I tightened the bolt to spec. After I did that and...   Mar 5, 2015 - 2:53 PM
- - rave2n   Are you sure you lined the top cap up properly wit...   Mar 5, 2015 - 3:09 PM
- - Jmk91   Yeah everything is lined up. New mount and strut h...   Mar 5, 2015 - 5:08 PM
- - RocketScott   Did you put the spacer back in? I'll try to f...   Mar 6, 2015 - 12:21 AM
- - RocketScott   It's the 90387-15012   Mar 6, 2015 - 12:34 AM
- - VavAlephVav   What about the little spacer washer that goes unde...   Mar 6, 2015 - 9:12 AM
- - Jmk91   I have the sports suspension package if that makes...   Mar 6, 2015 - 9:04 PM
- - Jmk91   Wait. Son of a .... I threw that away... Well look...   Mar 6, 2015 - 9:09 PM
- - rave2n   Damn. Done my rears 3 times now, and never really...   Mar 6, 2015 - 9:45 PM
|- - Box   QUOTE (rave2n @ Mar 6, 2015 - 8:45 P...   Mar 6, 2015 - 10:07 PM
- - Jmk91   Haha. Well I'll hopefully do it this weekend. ...   Mar 6, 2015 - 11:00 PM
- - RocketScott   I think I have a spare set of those if you need th...   Mar 6, 2015 - 11:50 PM
|- - Jmk91   QUOTE (RocketScott @ Mar 6, 2015 - 11...   Mar 6, 2015 - 11:57 PM
|- - RocketScott   QUOTE (Jmk91 @ Mar 6, 2015 - 8:57 PM...   Mar 7, 2015 - 10:00 AM
|- - Noahwhite2014   QUOTE (Jmk91 @ Mar 6, 2015 - 11:57 P...   Mar 13, 2015 - 3:57 AM
- - VavAlephVav   yep, just did mine a couple of weeks ago but had a...   Mar 7, 2015 - 2:38 AM
- - Jmk91   free image host Thanks you everyone. Its all fixe...   Mar 8, 2015 - 10:33 PM
|- - UTSlickVic   QUOTE (Jmk91 @ Mar 8, 2015 - 10:33 P...   Jan 14, 2016 - 11:15 AM
- - Box   Huzzah!   Mar 9, 2015 - 2:05 PM
- - Jmk91   The spacer goes on the top of the upper strut moun...   Jan 14, 2016 - 1:56 PM
- - Jmk91   Also its one spacer per side. The part number prob...   Jan 14, 2016 - 2:21 PM
Lo-Fi Version Time is now: September 1st, 2026 - 6:38 AM
