Mar 29, 2015 - 12:11 PM
Enthusiast Joined May 19, '14 From Waco TX Currently Offline Reputation: 0 (0%) |
okay, just started up my 7afe for the first time after putting it in. Started up first try and was idling high at just under 3k, let it run for about a minute then turned it off. adjusted the throttle cable a bit then got in to try and start it again. it wouldnt start and had zero power. no dash lights, no nothing. Any ideas?
This post has been edited by gbloomer: Mar 30, 2015 - 11:23 AM |
gbloomer Lost all Power Mar 29, 2015 - 12:11 PM
Bitter Nothing at all works? Horn, head lights, etc? Chec... Mar 29, 2015 - 5:11 PM
gbloomer QUOTE (Bitter @ Mar 29, 2015 - 6:11 ... Mar 29, 2015 - 7:20 PM
Box That and check the battery voltage. Could be batt... Mar 29, 2015 - 5:59 PM
Smaay check your grounds Mar 29, 2015 - 6:23 PM
Box ^Yep. Didn't see where he had just put it in ... Mar 29, 2015 - 7:21 PM
gbloomer QUOTE (Box @ Mar 29, 2015 - 6:59 PM)... Mar 29, 2015 - 7:24 PM
nics It might be the 100amp fuse. This happened to me, ... Mar 30, 2015 - 9:01 AM
gbloomer QUOTE (nics @ Mar 30, 2015 - 10:01 A... Mar 30, 2015 - 10:05 AM
Bitter Probably a battery cable or battery terminal issue... Mar 30, 2015 - 10:38 PM
Box That or you have a short somewhere. Mar 30, 2015 - 10:52 PM
gbloomer Okay Turns out it was the ground wires after all... Mar 31, 2015 - 10:06 AM![]() ![]() |
| Lo-Fi Version | Time is now: September 13th, 2026 - 10:54 PM |
