Feb 15, 2004 - 1:22 PM
Enthusiast ![]() Joined Feb 7, '04 From Calgary, Canada Currently Offline Reputation: 0 (0%) |
Where is there room to run wires from the dash to the trunk or from the center console to the trunk?
Feb 15, 2004 - 3:09 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) |
lift up ur door sills
Feb 15, 2004 - 5:25 PM
two options, runnign under door still 1st an norm bets, i ran my power an rca right through the center console then under the carpet an under the seats cause i was kinda short on power wire... very easy
Feb 18, 2004 - 4:16 AM
![]() Enthusiast ![]() ![]() Joined Sep 6, '03 From Fairbanks AK Currently Offline Reputation: 0 (0%) |
just make sure you keep the power wire separate from all other speaker or rca cables. I drilled a hole through the fire wall in the center and ran my power wire under the center console straight back, then the speaker and rca's down both sides.
Feb 18, 2004 - 7:33 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
were exactly is the hole in the engine bay between bay and interior of car because right now I got my wires going from my engine to fender and through door and I think it will look way more proffesional the other way. And if u did drill were did u drill the hole to not mess with anything?
-------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Feb 18, 2004 - 7:34 AM
I drilled a hole in the firewall area underneath the glovebox. I still need to seal it up with some silicon or something once I get the car back.
Feb 18, 2004 - 9:38 AM
Enthusiast ![]() ![]() Joined Dec 30, '03 From Atlanta Currently Offline Reputation: 0 (0%) |
Because mines an automatic, i drilled the hole where the clutch would go thought the firewall. |
Feb 18, 2004 - 1:36 PM
Enthusiast ![]() ![]() Joined Nov 26, '03 From McKenzie, TN Currently Offline Reputation: 0 (0%) |
In mine I drilled a hole on the driver's side of the firewall (actually 2 holes, but one was for my alarm) I ran it in just under the gauge cluster and then up through the center console and under the carpet. From there i ran it up through the side panel in the back seat to the trunk.
| Lo-Fi Version | Time is now: May 25th, 2026 - 6:49 PM |
