> Will a camry hub fit on a 6gc?
post Apr 20, 2015 - 12:13 PM
sircalebwhite
Joined Jan 12, '15
From Cambridge, Minnesota
Has anyone used a hub from a Camry on the front? Finding a used hub for the celi is like finding a needle in a hay stack.. just want to know if it would fit in case I hit another curb...
post Apr 20, 2015 - 1:05 PM
CrimsonSTX
Joined Jun 9, '07
From Miami, FL
Camry 1986-1991 will work as they are 5x100
1992 forward are 5x114.3
post Apr 23, 2015 - 6:12 AM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (CrimsonSTX @ Apr 20, 2015 - 11:05 AM) *
+1
post Apr 23, 2015 - 11:45 AM
Langing
Joined Apr 24, '14
From Durham, NC, USA
QUOTE (CrimsonSTX @ Apr 20, 2015 - 2:05 PM) *
Is that true for all 6gc?
post Apr 23, 2015 - 11:58 AM
Please dont put possible misguided information. If the bearing is not the same, then it wont fit. Bearings make a lot of difference and so does the spline count for the axles. Unless someone ha verified this, beware...
post Apr 23, 2015 - 1:08 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Langing @ Apr 23, 2015 - 9:45 AM) *
Yes for fwd 6gc.
post Apr 24, 2015 - 1:10 PM
CrimsonSTX
Joined Jun 9, '07
From Miami, FL
QUOTE (njccmd2002 @ Apr 23, 2015 - 12:58 PM) *
I have the hub from a 1990 Camry on my front driver side. I installed it in August 2011. The bearing is for a Celica, ordered from amazon. I sat in the muddy junkyard, old hub in one hand and counted the splines myself before I removed the hub from the Camry. So in a way I have "verified" it. My car is a 1995 St and it's my daily driver. That's just my experience.
post Apr 24, 2015 - 4:05 PM
Good then.
post Apr 24, 2015 - 4:06 PM
Langing
Joined Apr 24, '14
QUOTE (CrimsonSTX @ Apr 24, 2015 - 2:10 PM) *
I think you are talking about front wheels? Was the steering knuckle of that 1990 Camry the same as the one on your 1995 Celica? Since the bearing and hub were identical, I'm just wondering how much of the wheel was the same from that series of Camry.
post Apr 24, 2015 - 5:54 PM
CrimsonSTX
Joined Jun 9, '07
From Miami, FL
QUOTE (Langing @ Apr 24, 2015 - 5:06 PM) *
Not sure how much of the Steering is the same.
Maybe someone more knowledgeable has the answer.
post Apr 25, 2015 - 11:50 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
use toyodiy to verify part numbers interchange, that's the easiest way.
post May 1, 2015 - 12:11 PM
Arturio55
Joined Mar 6, '13
From New jersey
I just ordered the 1990 camry front hub (duralast) from autozone
anyone know if we can use the bearing that comes with it?
QUOTE (Azncelica @ Mar 4, 2012 - 11:43 PM) *
I started with what I know to do, I swap engine into my car, I knew it was too much work to make it a AWD. I kept it FWD. Went to take a crack at doing the wiring conversion. Than, I realize, shoot, this is out of my league.
post Jun 12, 2015 - 11:56 PM
black13
Joined Oct 11, '06
From calgary
What about 7th gen celica hub? does it fit 6gc?
Lo-Fi Version Time is now: June 28th, 2026 - 6:49 AM
