> Buzzing from sub?, I'm getting an annoying buzz with my new custom sealed box
post Apr 30, 2015 - 7:21 PM
Noahwhite2014
Joined Jul 1, '14
From Hawaii
So I made a sealed box that takes up the inside of the spare tire well and has a false floor baffle flush with the rear seats in the down position. The volume on the interior is around 2.85 cubic feet and there is cushion foam lining the floor pan in the back. The whole box is bolted down to the spare tire tie down hole and that is also the ground point I'm using for the amp. Here's a picture of it.
Looks great and sounds great, but at certain frequencies I get a buzz from my plastics in the back. I believe it's also buzzing the bumper and license plate bezel (not the license plate itself since it has a rubber "anti vibration" frame.
Anyone have a good way to quiet that crap down? Lol
- Noahwhite2014   Buzzing from sub?   Apr 30, 2015 - 7:21 PM
- - Box   Sound insulation!   Apr 30, 2015 - 7:51 PM
- - Bitter   Adding mass to the metal panels may reduce or alte...   Apr 30, 2015 - 11:30 PM
- - The_enD   Read up! http://www.sounddeadenershowdown.com/   May 1, 2015 - 2:09 AM
- - Noahwhite2014   Thanks for the replies! I Forgot to mention I ...   May 1, 2015 - 7:20 AM
- - Box   You could use rubber insulation spray on all the b...   May 1, 2015 - 1:59 PM
- - Jmk91   I love the way you have that box set up. Looks ama...   May 1, 2015 - 5:18 PM
- - Box   You forgot about Dual. Pyle is slightly better, b...   May 1, 2015 - 8:54 PM
- - Jmk91   Kicker is weird about box sizes. My kicker comp r ...   May 2, 2015 - 12:41 AM
- - Noahwhite2014   Lol yeah I just bought that amp because at the tim...   May 2, 2015 - 7:11 AM
- - Bitter   For all intents and purposes a sub amp is a sub am...   May 2, 2015 - 9:32 AM
- - Box   Signal to noise ratio and frequency response yo. ...   May 2, 2015 - 12:11 PM
- - Bitter   http://www.bossaudio.com/auto/car-audio-so...s-aud...   May 2, 2015 - 1:00 PM
- - Jmk91   I know his amp isn't causing the real issue ha...   May 2, 2015 - 1:17 PM
- - Box   Amps colour the sound as well, but in these instan...   May 2, 2015 - 3:22 PM
- - Noahwhite2014   After a little bit of testing at work with the car...   May 2, 2015 - 5:39 PM
- - Box   If it's cutting out low frequencies that'd...   May 2, 2015 - 6:50 PM
- - Jmk91   Yeah I have mine set at 80 and lower go to sub any...   May 2, 2015 - 8:18 PM
- - Box   Just depends on the woofer, most have a response o...   May 2, 2015 - 10:12 PM
- - Jmk91   To an extend. The mid drives deliver more on 100+ ...   May 2, 2015 - 11:49 PM
- - Box   Or be super OCD and run a 15" from 20-100, th...   May 3, 2015 - 12:30 AM
- - Box   ...   May 3, 2015 - 12:34 AM
- - Jmk91   Not really. 15 inch sub is useless unless you list...   May 3, 2015 - 11:04 AM
- - Box   Not all 15's have terrible response, of course...   May 3, 2015 - 12:58 PM
- - Jmk91   Almost all 15s are horrible. I haven't seen on...   May 3, 2015 - 3:12 PM
- - Box   It's also a matter of enclosure, if it's n...   May 3, 2015 - 5:48 PM
- - Jmk91   I've never seen in a car. I've been to man...   May 3, 2015 - 8:29 PM
- - Box   What do you think they use at concerts to project ...   May 3, 2015 - 11:19 PM
- - Box   I like how this has completely ventured off from t...   May 3, 2015 - 11:32 PM
- - Jmk91   Haha I guess we did. Oh well haha. I see what your...   May 4, 2015 - 7:50 AM
- - Box   Just looked up the datasheet for the 15" in m...   May 4, 2015 - 8:03 AM
- - Jmk91   500w or RMS? Wattage is nothing the RMS is what ma...   May 4, 2015 - 2:37 PM
- - Box   Even RMS can be sketchy unless it's CEA certif...   May 4, 2015 - 2:53 PM
- - Jmk91   I'm confused with your last statement. Most su...   May 4, 2015 - 4:42 PM
- - Jmk91   Also dvc and SVC are basically the same. Only diff...   May 4, 2015 - 4:46 PM
- - Box   PA cabinets can vary wattage with ohms, which I kn...   May 4, 2015 - 5:29 PM
- - Jmk91   Ohhh okay I see   May 4, 2015 - 6:00 PM
- - Bitter   The 6x9's in the back of my Mazda keep up with...   May 5, 2015 - 7:02 PM
- - Jmk91   Home audio is mostly rated at 8 ohms tho. So no am...   May 5, 2015 - 9:26 PM
- - Bitter   Hmm so how am I thumping away a pair of 6x9 8ohm T...   May 5, 2015 - 9:40 PM
- - Jmk91   On your first post you never stated you had an amp...   May 5, 2015 - 10:12 PM
- - Jmk91   At first I was like how are you getting any thump ...   May 5, 2015 - 10:18 PM
- - Bitter   We're talking about subs, why on earth would a...   May 5, 2015 - 10:19 PM
- - Jmk91   Bro you said 6x9... 6x9 isn't a real sub. Or a...   May 5, 2015 - 11:17 PM
- - Bitter   35hz is as low as it goes on paper in sealed or po...   May 5, 2015 - 11:27 PM
- - Jmk91   Lol are you kidding me? I've been messing with...   May 5, 2015 - 11:39 PM
Lo-Fi Version Time is now: September 3rd, 2026 - 2:36 AM
