Apr 30, 2015 - 7:21 PM
Enthusiast ![]() ![]() Joined Jul 1, '14 From Hawaii Currently Offline Reputation: 3 (100%) |
So I made a sealed box that takes up the inside of the spare tire well and has a false floor baffle flush with the rear seats in the down position. The volume on the interior is around 2.85 cubic feet and there is cushion foam lining the floor pan in the back. The whole box is bolted down to the spare tire tie down hole and that is also the ground point I'm using for the amp. Here's a picture of it.
![]() Looks great and sounds great, but at certain frequencies I get a buzz from my plastics in the back. I believe it's also buzzing the bumper and license plate bezel (not the license plate itself since it has a rubber "anti vibration" frame. Anyone have a good way to quiet that crap down? Lol |
Noahwhite2014 Buzzing from sub? Apr 30, 2015 - 7:21 PM
Box Sound insulation! Apr 30, 2015 - 7:51 PM
Bitter Adding mass to the metal panels may reduce or alte... Apr 30, 2015 - 11:30 PM
The_enD Read up!
http://www.sounddeadenershowdown.com/ May 1, 2015 - 2:09 AM
Noahwhite2014 Thanks for the replies! I Forgot to mention I ... May 1, 2015 - 7:20 AM
Box You could use rubber insulation spray on all the b... May 1, 2015 - 1:59 PM
Jmk91 I love the way you have that box set up. Looks ama... May 1, 2015 - 5:18 PM
Box You forgot about Dual. Pyle is slightly better, b... May 1, 2015 - 8:54 PM
Jmk91 Kicker is weird about box sizes. My kicker comp r ... May 2, 2015 - 12:41 AM
Noahwhite2014 Lol yeah I just bought that amp because at the tim... May 2, 2015 - 7:11 AM
Bitter For all intents and purposes a sub amp is a sub am... May 2, 2015 - 9:32 AM
Box Signal to noise ratio and frequency response yo. ... May 2, 2015 - 12:11 PM
Bitter http://www.bossaudio.com/auto/car-audio-so...s-aud... May 2, 2015 - 1:00 PM
Jmk91 I know his amp isn't causing the real issue ha... May 2, 2015 - 1:17 PM
Box Amps colour the sound as well, but in these instan... May 2, 2015 - 3:22 PM
Noahwhite2014 After a little bit of testing at work with the car... May 2, 2015 - 5:39 PM
Box If it's cutting out low frequencies that'd... May 2, 2015 - 6:50 PM
Jmk91 Yeah I have mine set at 80 and lower go to sub any... May 2, 2015 - 8:18 PM
Box Just depends on the woofer, most have a response o... May 2, 2015 - 10:12 PM
Jmk91 To an extend. The mid drives deliver more on 100+ ... May 2, 2015 - 11:49 PM
Box Or be super OCD and run a 15" from 20-100, th... May 3, 2015 - 12:30 AM
Box ... May 3, 2015 - 12:34 AM
Jmk91 Not really. 15 inch sub is useless unless you list... May 3, 2015 - 11:04 AM
Box Not all 15's have terrible response, of course... May 3, 2015 - 12:58 PM
Jmk91 Almost all 15s are horrible. I haven't seen on... May 3, 2015 - 3:12 PM
Box It's also a matter of enclosure, if it's n... May 3, 2015 - 5:48 PM
Jmk91 I've never seen in a car. I've been to man... May 3, 2015 - 8:29 PM
Box What do you think they use at concerts to project ... May 3, 2015 - 11:19 PM
Box I like how this has completely ventured off from t... May 3, 2015 - 11:32 PM
Jmk91 Haha I guess we did. Oh well haha. I see what your... May 4, 2015 - 7:50 AM
Box Just looked up the datasheet for the 15" in m... May 4, 2015 - 8:03 AM
Jmk91 500w or RMS? Wattage is nothing the RMS is what ma... May 4, 2015 - 2:37 PM
Box Even RMS can be sketchy unless it's CEA certif... May 4, 2015 - 2:53 PM
Jmk91 I'm confused with your last statement. Most su... May 4, 2015 - 4:42 PM
Jmk91 Also dvc and SVC are basically the same. Only diff... May 4, 2015 - 4:46 PM
Box PA cabinets can vary wattage with ohms, which I kn... May 4, 2015 - 5:29 PM
Jmk91 Ohhh okay I see May 4, 2015 - 6:00 PM
Bitter The 6x9's in the back of my Mazda keep up with... May 5, 2015 - 7:02 PM
Jmk91 Home audio is mostly rated at 8 ohms tho. So no am... May 5, 2015 - 9:26 PM
Bitter Hmm so how am I thumping away a pair of 6x9 8ohm T... May 5, 2015 - 9:40 PM
Jmk91 On your first post you never stated you had an amp... May 5, 2015 - 10:12 PM
Jmk91 At first I was like how are you getting any thump ... May 5, 2015 - 10:18 PM
Bitter We're talking about subs, why on earth would a... May 5, 2015 - 10:19 PM
Jmk91 Bro you said 6x9... 6x9 isn't a real sub. Or a... May 5, 2015 - 11:17 PM
Bitter 35hz is as low as it goes on paper in sealed or po... May 5, 2015 - 11:27 PM
Jmk91 Lol are you kidding me? I've been messing with... May 5, 2015 - 11:39 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 10:09 AM |
