May 10, 2015 - 1:36 PM
Enthusiast Joined Mar 20, '15 From Sacramento Currently Offline Reputation: 0 (0%) |
Hey guys,
A long time ago i went Yokohama V4S 205-55-15 tires. They were great tires and lasted me 8 years and 120k miles. I rotate every 2 oil changes and i run Neg 2 camber front and neg 1 in the back. Its that time where my tires are near slicks bald. I go to find the same tires again and Yokohama no longer makes V4S in 205-55-15. In fact it shows the V4S was replaced by the Envigor which isnt available in 205-55-15. Yokohama now has S-Drive in 205-55-15 anyone runs these? Other then this i almost have no other choices in 205-55-15 .. even the tire shop said i have an oddball tire size If i step it down to a 205-50-15 i have a huge list of nice performance tires. my problem is the S54 tranny has such short gear ratios going down a little makes my RPM even high for highway use. If i go up to 205-60-15 i get all these tires with soft side walls which reduces steering response What tires do you guys like and hows your experience with them? This post has been edited by Driftinharmony: May 11, 2015 - 11:56 PM |
May 21, 2015 - 12:15 AM
Enthusiast ![]() Joined Jan 12, '15 From Cambridge, Minnesota Currently Offline Reputation: 0 (0%) |
I'm in the same boat. I found Kumho Ecsta and some Dunlops on tirerack.com and discounttire.com so check those sites out but i prefer the Yokahomas. Very good tires. Just our tire size sucks. Can't even find these size tires used anywhere..
May 26, 2015 - 3:08 AM
I'm in the same boat. I found Kumho Ecsta and some Dunlops on tirerack.com and discounttire.com so check those sites out but i prefer the Yokahomas. Very good tires. Just our tire size sucks. Can't even find these size tires used anywhere.. after shopping around for something to replace 205-55-15. I found many nice tires in 205-50-15. Using those will give faster acceleration, better response, and a more harsh ride. Then you have to worry about the short gearing for highway use, because your rpm will be even higher at 70mph. There are many nice tires in 205-60-15. Using these will have a slower acceleration, sluggish response, and more comfortable ride. At 70mph your RPM will be lower allowing you to save gas. If i stay at 205-55-15 i have about 4 options non which i like. My car is a daily car. 300 tread wear can wear very fast. I wanted something better for the commute yet delivers performance if i need it. I absolutely loved my Yokohama v4s but they replaced it with the Avid ENVigor. Its supposed the updated version of the v4s but they dont make it in 205-55-15 So i think im going to try 205-60-15 Avid ENVigor ...my car is pretty low...the extra sidewall can bring it up a lil bit too |
May 26, 2015 - 10:21 PM
Enthusiast ![]() ![]() ![]() Joined Jan 25, '15 From United States Currently Offline Reputation: 4 (100%) |
Yokohomas S drive is a good tire. I had them before and loved them. I'd buy them again honestly. They are rated for 60k mile warranty.. But you'll most.likely get 40-45k out of them and they'll be at 2/32nds.
Jun 8, 2015 - 8:20 PM
Enthusiast ![]() Joined Oct 25, '12 From Pennsylvania Currently Offline Reputation: 0 (0%) |
My '97 convertible had Bridgestone Potenzas on when I bought the car, and I changed them to Kumho Ecsta tires on tirerack.com. They handled better than the Bridgestones, and I was finally able to drive in snow(!!!). The first set of Kuhmos had about 12,000 miles on them when I bought a set of rims and another set of Kuhmos from Tirerack this past winter. The original set looked as good as new, and I sold the factory rims and Kuhmos in about 30 minutes on Craigslist. My wife and I drive some really winding roads on the weekend, and push the car around tight bends with zero problems.
| Lo-Fi Version | Time is now: March 2nd, 2026 - 12:28 AM |
