May 26, 2015 - 9:18 PM
Enthusiast ![]() ![]() Joined Jun 21, '14 From Ottawa, Ontario, Canada Currently Offline Reputation: 0 (0%) |
My efing valves are leaking! I lapped them down to the right height as suggested by delta cams. Now after installing the valve springs I poured some paint thinner in the ports to do a leak test and the thinner is coming out through the valves and into the combustion chamber. Any thoughts?? What did I do wrong?
doory100 Leaking valves May 26, 2015 - 9:18 PM
Bitter Well valves don't seal 100% when they're f... May 26, 2015 - 9:47 PM
doory100 that's what I thought. are you sure? May 27, 2015 - 5:23 AM
Smaay what did you set the valve clearance too? May 27, 2015 - 9:30 AM
Bitter I'm assuming you have a nice even gray band al... May 27, 2015 - 10:58 AM
doory100 QUOTE (Smaay @ May 27, 2015 - 10:30 ... May 27, 2015 - 6:46 PM
Bitter Might need more than a wipe with a rag, try a spra... May 27, 2015 - 8:11 PM
doory100 Ok but should they be water tight or do they need ... May 27, 2015 - 9:38 PM
Bitter I think they need to run a bit first, you've g... May 27, 2015 - 11:01 PM
Box Like already mentioned make sure all of the compou... May 28, 2015 - 1:07 AM
enderswift the pressure of compression and combustion helps s... May 28, 2015 - 7:12 AM
RocketScott They should seal, there isn't a break in with ... May 28, 2015 - 9:05 PM
doory100 I lapped in new valves with a drill. The drill had... May 28, 2015 - 10:06 PM
TerryE You might want to take your head in and have it do... Jun 2, 2015 - 1:32 AM
TerryE P.S. Don't watch Youtube so much. Jun 2, 2015 - 1:42 AM
doory100 the only reason for the drill was that I had to se... Jun 5, 2015 - 10:45 PM
doory100 Here are some pictures of the valve stem seats.
... Jun 5, 2015 - 10:52 PM
Smaay what valves are those? they are NOT OEM Jun 7, 2015 - 10:00 PM
doory100 no there not oem. Why are you jealous?
Got them t... Jun 8, 2015 - 11:31 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 15th, 2026 - 7:47 PM |
