> Need help please, Electrical gremlins
post Jun 22, 2015 - 6:21 AM
toyota123
Joined Jan 13, '12
From Georgia
So about a mile away from the house this morning I noticed my windows wouldn't go down, my instrumentppanel wasn't working and also the sunroof was out of commission. The car made the hour drive to work and now it won't start. The wierd part is all of my lights worked just ffine until I pulled into the parking lot at work when they all shut off. I haven't done anything new or changed anythingrrecentlysso I'm kind of at a lossoon this one. Any help you have would be great
97 Celica GT liftback DD/ project
96 corolla back up DD
- toyota123   Need help please   Jun 22, 2015 - 6:21 AM
- - toyota123   Just got done checking the basics all the fuses an...   Jun 22, 2015 - 6:39 AM
- - toyota123   11 v while running, turn the lights on and it drop...   Jun 22, 2015 - 6:51 AM
- - Tigawoods   check the output of the alternator. Volt meter, Po...   Jun 22, 2015 - 9:12 AM
- - toyota123   Was about 10.5 just not sure if it's the root ...   Jun 22, 2015 - 9:43 AM
- - Tigawoods   thats your problem, it should be outputting betwee...   Jun 22, 2015 - 10:14 AM
- - VavAlephVav   Yup, You should be able to stop at an AutoZone or ...   Jun 22, 2015 - 11:48 AM
- - Box   Definitely the alternator, that or the belt is loo...   Jun 22, 2015 - 12:24 PM
- - toyota123   Well just got done switching the alternator and no...   Jun 22, 2015 - 12:51 PM
- - Smaay   with the engine running, you should get 14.4 to 14...   Jun 22, 2015 - 2:44 PM
- - toyota123   problem solved it turned out to be a combination o...   Jun 22, 2015 - 9:55 PM
- - Box   Glad you got it fixed, sucks you had to pay for a ...   Jun 22, 2015 - 10:05 PM
- - toyota123   Thought it was fixed. Today it did the same thing...   Jun 23, 2015 - 5:24 PM
- - Box   I would check all of your body grounds and make su...   Jun 23, 2015 - 6:43 PM
- - toyota123   Thanks box I'll check them after work today   Jun 24, 2015 - 4:57 AM
- - toyota123   While investigating I re pulled the electrical soc...   Jun 25, 2015 - 7:51 AM
- - toyota123   Well no luck there. At a loss as to where to ev...   Jun 25, 2015 - 5:48 PM
- - Box   If you haven't checked all of the grounds yet ...   Jun 25, 2015 - 7:32 PM
- - toyota123   Checked the grounds they all look to have good con...   Jun 26, 2015 - 4:12 PM
- - Box   Before you start going crazy I'd make sure the...   Jun 26, 2015 - 5:51 PM
- - Noahwhite2014   I had a bad battery once that caused a headache, l...   Jun 27, 2015 - 3:54 PM
- - toyota123   Either the batter is good or I have 2 bad batterie...   Jun 28, 2015 - 11:42 AM
Lo-Fi Version Time is now: August 4th, 2026 - 3:35 PM
