Jul 17, 2015 - 9:14 AM
![]() Enthusiast ![]() Joined Apr 25, '13 From Pittsburgh Currently Offline Reputation: 0 (0%) |
ok,
waterpump gasket turned into replacement of ALL engine gaskets and a thorough cleaning or the bay and the tucking of a few wires, and relocation of one out of place power steering fluid tank... rebuild went slow and steady, and then came the time to crank. *Ffffffppppppptttttttt* Fauq. Spins, but no vroom. i then went in and checked time a whatnot and went back in. now, obviously i was orginally getting crank, and i then i blew a whole row of fuses when arcing alternator (fauq) replaced every fuse and maxxi fuse and im at the point now that i get main power. turn signals work, a couple dash lights come on no door chime no radio no windows...no fuel no crank.... nothing like that...now, i did bypass the alternator fuse, but it has a good connection.. there is a 3d27 fuse that might be blown but i can tell though to be sure.... they have that opaque casing, but there is discoloration at the base, so im thinking kicked.... or i cooked the pcm/ecu ![]() ![]() directions? ideas? help? This post has been edited by slo_celly: Jul 17, 2015 - 9:26 AM -------------------- |
Jul 17, 2015 - 9:49 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) |
Seeing as you tucked some wires I would think that there is a fault in there somewhere, you shouldn't be blowing fuses like that just from doing basic maintenance. I would just re trace your wiring and double check your work.
![]() Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
Jul 17, 2015 - 11:08 AM
Seeing as you tucked some wires I would think that there is a fault in there somewhere, you shouldn't be blowing fuses like that just from doing basic maintenance. I would just re trace your wiring and double check your work. while its not blowing fuses now, there were a few questionable wires under the fuse box in the bay. im going in now to check those. -------------------- |
Jul 18, 2015 - 11:29 AM
Do anything with timing?
| Lo-Fi Version | Time is now: July 29th, 2026 - 12:50 AM |
