Jul 28, 2015 - 5:22 PM
Enthusiast ![]() Joined Jul 12, '15 From Iowa Currently Offline Reputation: 1 (100%) |
Hey, I am going to be doing a manual swap in my 95 gt Convertible. I am planning on buying a parts car instead of trying to hunt down all the parts. My question is, as long as I find a 94-99 gt with the same 2.2 5sfe motor with a manual tranny, does it matter if it's not a convertible like mine? Will all the parts still interchange? Including the ecu?
Jul 28, 2015 - 10:31 PM
yes, no problem.
Jul 29, 2015 - 2:23 PM
Awesome, thanks
Jul 29, 2015 - 8:24 PM
The only thing you'll need to watch for is OBDI or OBDII. You wouldn't want to plug an OBDII ECU from your parts car up to an OBDI engine/harness in your current car. Apart from that, it'll all work perfectly.
Sep 5, 2015 - 12:55 AM
Enthusiast Joined Mar 13, '15 From Washington State Currently Offline Reputation: 0 (0%) |
The only thing you'll need to watch for is OBDI or OBDII. You wouldn't want to plug an OBDII ECU from your parts car up to an OBDI engine/harness in your current car. Apart from that, it'll all work perfectly. If it was off an obd II car would you just need to transfer the the wiring harness from dash/engine bay? -------------------- 95 GT Convertible 2.2L 5S-FE Auto
Purple-Blue Given to me with bad tranny Going to bring car back to life. 160K miles |
| Lo-Fi Version | Time is now: June 11th, 2026 - 9:52 PM |
