2 Pages V  < 1 2
> Which clutch should I use???
post Aug 6, 2015 - 5:43 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (JohnnyGat0519 @ Aug 5, 2015 - 7:11 AM) *
I saw in the dyno results page, and it seemed that some people with similar set ups were pushing 250-270 lbs at the wheels. Are they doing something more, or should I expect high torque results? Also the 225 lbs capacity is at the crank. I have now seen the have a stage 3 daily, which is more for daily drive, but has a 300 lb capacity. I spoke with Dave at Southbend, and he pointed me towards this one, because I was not sure what to expect for torque results. This one sounds good, but is $250 more!! And I don't want to spend that if I don't need to. What kind of torque should I expect with my projected set up????
Stock 5sfe
3sgte twin entry ct26 turbo, manifold, map sensor, oil pan
3" aftermarket downpipe
Custom 3" exhaust
2 1/2" intercooler piping with front mount intercooler
Rx-7 460cc injectors
Factory fuel pump
Greddy emanage blue, dyno tuned
8-10 psi
you are going to make about 200 lbs at most. dont read into this too much. Thats the same setup I had before i went to V6. the stage 2 will be fine
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Aug 6, 2015 - 5:47 PM
Box
Joined Feb 23, '12
From Warrior, AL
Listen to the Smaay, he's been there and done that with just about everything pertaining to the Celica.
2001 Miata LS 5-speed
post Aug 6, 2015 - 8:38 PM
JohnnyGat0519
Joined Jul 12, '15
From Iowa
QUOTE (Smaay @ Aug 6, 2015 - 5:43 PM) *
Stock 5sfe
Custom 3" exhaust
Factory fuel pump
8-10 psi
Thanks Smaay, just to clarify, are u saying I'd be good with the stage 2 daily with 225 lbs at the crank capacity, or would I need the stage 2 endurance with 295 lbs at the crank capacity ??
post Aug 7, 2015 - 1:54 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
225 will be fine.
post Aug 7, 2015 - 6:56 AM
JohnnyGat0519
Joined Jul 12, '15
From Iowa
QUOTE (Smaay @ Aug 7, 2015 - 2:54 AM) *
225 will be fine.
Thanks again Smaay, and if u know anything about front and rear lips, I have a post in exterior styling I need some help with. Lol
2 Pages V  < 1 2
Lo-Fi Version Time is now: August 31st, 2026 - 10:38 AM
