Aug 17, 2015 - 5:34 PM
Enthusiast ![]() Joined Apr 19, '08 From Norway Currently Offline Reputation: 0 (0%) |
After a workshop swapped the engine in my st205, the air from the heater ranges from warm to very warm. Where should i start? (Any help from the workshop is completely off the table.
Aug 17, 2015 - 7:31 PM
Enthusiast ![]() Joined May 15, '12 From Renton, WA Currently Offline Reputation: 0 (0%) |
After a workshop swapped the engine in my st205, the air from the heater ranges from warm to very warm. Where should i start? (Any help from the workshop is completely off the table. http://www.6gc.net/forums/index.php?showtopic=53845 Check the heater control valve to ensure its operating as expected. Since you are post-swap, the cooling system may not have been bled properly. I would rebleed your cooling system. |
Aug 23, 2015 - 8:16 AM
The valve is controlled properly by the knob, and i have now flushed and changed the coolant. Still warm air only.
Aug 23, 2015 - 10:37 AM
It can be really hard to fully purge air from the heater core. put the front of the car up and allow it to idle with the radiator cap off for about 15 minutes, fill the radiator and bottle, put the cap back on, then hold the engine at about 2000-2500 RPM for about 5-10 minutes. You may hear some gurgling and suddenly have nice hot air from the vents. Let the car cool over night and top the coolant bottle.
| Lo-Fi Version | Time is now: July 29th, 2026 - 5:12 PM |
