Aug 21, 2015 - 7:43 PM
Enthusiast ![]() Joined Aug 21, '15 From Michigan Currently Offline Reputation: 0 (0%) |
Does anyone know where I can find 220cc/min injectors for my Celica ST 7A-FE? I have a slightly modified engine and the stock ones won't work out. I don't need racing injectors like what RC Engineering are, I just need a simple step up. I could run 215's minimum but I am having a very difficult time even finding any of these injectors.
Aug 22, 2015 - 6:42 AM
Enthusiast ![]() ![]() Joined Jun 21, '14 From Ottawa, Ontario, Canada Currently Offline Reputation: 0 (0%) |
Do you have a engine management system? Like a piggy back or stand alone ecu?
This post has been edited by doory100: Aug 22, 2015 - 6:42 AM -------------------- |
Aug 22, 2015 - 8:00 AM
03+ Celica GTS uses brown 320cc/min injectors. 1ZZ uses a 255cc/min injector that's green and also comes in many things not Celica like Corolla's as well. I don't know if they're low or high impedance though.
http://www.monkeywrenchracing.com/product_...roducts_id=1528 -------------------- |
Aug 22, 2015 - 9:36 AM
Do you have a engine management system? Like a piggy back or stand alone ecu? I know there are some out there that don't require ECU modifications. Last I heard the 7A-FE had 200cc/min injectors, and I was thinking about going a little bigger. But now I'm being told to just run stock since I'm not getting any lean conditions thrown from my O2 sensor. I'm just getting a cylinder 3 misfire which I've already replaced my spark plugs and wires, and my distributor is fine. If I go stock, I'll run with Denso but they're also a little hard to find. 350cc/min is way too big. It's not TC or SC so I don't need that. 255cc/min is still rather large too.. |
Aug 22, 2015 - 10:46 PM
wow you are really trying to blow money. unless you are turboed, stock injectors are fine.
Aug 22, 2015 - 11:09 PM
wow you are really trying to blow money. unless you are turboed, stock injectors are fine. Already bought stock injectors. Though an entire set I found for around 149 USD for 220cc. But I'm fine with stock. I had already sent two different posts earlier and they didn't send which kinda frustrated me. |
| Lo-Fi Version | Time is now: June 14th, 2026 - 1:18 PM |
