Aug 26, 2015 - 10:08 AM
Enthusiast ![]() Joined Jan 23, '13 From New Jersey Currently Offline Reputation: 0 (0%) |
HERES THE CL ADD WITH PICS
pictures are as of today 8/25/15 1997 celica hatchback for sale or trade, I need the money ASAP to buy a bigger car, would consider trading for a ford escape 09+, lincoln towncar 07+, a minivan 2008+ tell me what you have or your offer, Im technically giving you the car for free and only charging you for some parts for this price!yet still a bit negotiable text me an offer worst I could say is no, my phone number is in the CL add TEXT ONLY, I spend months without using this forum some highlights; -2 sets of wheels 1 set x4 15 inch ASA wheels black with tires 2 good 2need to be replaced 1 set x4 16 inch 2006 Celica GTS wheels oem installed with new yokahama tires I got like 4 months ago. brand new battery from TOYOTA about 3 months old rear view camera, panasonic radio CD player with aux in for your phone, tablet or laptop, and subs I bought this celica cheap with many issues which I have fixed, about 3400$ later just in parts, the car runs and drives like new! and im 100% sure you can put another 100,000 miles on it with no problems, I thought I was going to keep it for ever, but now I need a newer bigger car for work im a die hard toyota fanatic and ive been restoring this car for over 2 years and a half but I dont have a garage or a driveway to park it, but my uncle told me to park it in his driveway for 1 month after that i will be having to move it around to avoid sweeping tickets which is a pain and paying insurance and registration for a car thats not being used. so here are the details $*$*$*$*$ THINGS INCLUDED WITH THE CAR *$*$*$*$*$ # Pioneer radio CD player with AUX input to plug your iPhone, Android phone, or laptop **INSTALLED # Pioneer amplifier **INSTALLED # 2 12" inch infinity subs **INSTALLED # a second set of 15 inch wheels with tires 2 tires are good 2 are bad, you can put a set of snow tires on this set and use them as your winter set and use the other as your summer set, that way the tires will last longer and its cheaper than just swapping the tires on the same wheels. # a second set of tail lights that are red out and smoked for car shows # a set of round foglights if I can find them # all weather rubber floormats **INSTALLED # rear view wide angle cameras with a 7 inch display PERFECT for new drivers --INSTALLED # 2 extra tail light wiring harnesses if I can find them I really want this car to be driven and have a good owner thats going to take good care of it and love it as much as I do! $$$ Here is a parts list of things I have changed $$$ ***6 months or less ago*** # brand new alternator # alternator belt # AC compressor belt # Brand new Timing belt # water pump # oil seals for the crankshaft and camshafts # timing belt tensioners # spark plug wires # spark plug wire separators # 4 brand new yokahama tires from Tirerack.com # both front diamond lightly smoked corner lights # right rear shock absorber # ALL 4 swaybar links # both front CERAMIC brake pads, the highest quality brake pads you can get for this car! ***about 1 year ago**** # both axles # left front brake rotor # left front bearing # 4 newer 16" inch Wheels from a 2006 Celica GTS OEM # Rear View Camera with a 7 inch display # 5% tinted rear windows fully legal # new exhaust header heat shield # OEM but custom molded slick looking side view mirrors that fold too, and the miror part is fully electric # driver side headlight # both low beam light bulbs sylvania # valve cover gasket # o ring gaskets for the spark plugs # coolant flush # thermostat with gasket # painted gloss black all the black plastic accents # plasti dipped a blue european style racing stripe but I just removed it # New battery post clamp thing # brake light bulbs **about 2 years ago** # rainx latitude wiper blades the best in the market they worked perfect until the last time I drove the car, I highly recommend getting the same if you replace them, they are simply the BEST! # spark plug wires # driver side headlight bulb # lift gates shocks # fixed some dents on drivers side # replaced both air bags the car was in a minor accident that broke the headlight and the fender got dented, the high beam hit the airbag sensor, I have pictures before the repair so you can see how minor it was just ask for pictures and ill send them thats how I bought it # replaced the interior door panel on 1 of the doors becacuse it was faded from the sun a bit # installed a pioneer radio and infinity subs THE BAD # you might want to check the front right bearing, since I replaced the left one because it was bad, the right one will soon need to be replaced. # the AC leaks a bit of water inside the car, I was going to make a plastic or fiberglass liner to catch the droplets, but havent had time. and I dont know how to work with A/Cs and refrigerants to fix the source problem # the car could use a paint job and a few dents fixed ############ PLEASE NOTE ############### IF you do decide to paint the car, PLEASE get in coordination with me so you can take it to a body shop on my day off, and I will buy the necessary tape and paper to mask the car and I WILL mask the car myself FOR FREE!!!, DO NOT trust any body shop with that, I made that mistake 3 times with some of my other cars at different body shops, and I want this car to look perfect even if Im not the one thats going to enjoy driving it! I LOVE this car, and I HATE the fact I need the money to buy a bigger car for work, but eventually Ill get another one, once I save enough with the new job, but Ill definitely miss this one This post has been edited by TheCreatorOf: Sep 23, 2015 - 7:30 PM -------------------- white 1997 Celica GT***FOR SALE
TheCreatorOf SOLD FS/FT white 97 GT hatchback NJ paterson Aug 26, 2015 - 10:08 AM
ucf3 too rich for my blood. Sep 3, 2015 - 10:16 AM
TheCreatorOf bump Sep 4, 2015 - 2:14 AM
TheCreatorOf bump Sep 6, 2015 - 1:17 PM
TheCreatorOf bump reduced price Sep 7, 2015 - 10:55 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 30th, 2026 - 11:51 PM |
