> Help!! Celica is runnig rich at idle, Celica is up and running today.
post Aug 28, 2015 - 5:53 PM
doory100
Joined Jun 21, '14
From Ottawa, Ontario, Canada
Celica is up and running today. It's running super rich especially at idle. Any idea what may be the problem? My afr guage is buried at 10 and its burning black soot out the tail pipe.. It drives pretty good but it's jumpy when I let off the accelerator. I have a apexi neo safc installed. any links on how to set this up?
This post has been edited by doory100: Aug 28, 2015 - 7:03 PM
- doory100   Help!! Celica is runnig rich at idle   Aug 28, 2015 - 5:53 PM
- - Box   Coolant temp sensor and primary O2 sensor are resp...   Aug 28, 2015 - 7:12 PM
- - doory100   is the primary o2 sensor, the one with the two bol...   Aug 28, 2015 - 7:21 PM
- - Bitter   Is the engine light on? What's the AFC set to?...   Aug 28, 2015 - 7:32 PM
- - doory100   yes the engine light is on. It was set to zero. bu...   Aug 28, 2015 - 7:40 PM
- - Bitter   Yes, pressure sensor. What's the code set?   Aug 28, 2015 - 8:01 PM
- - doory100   Code set?   Aug 28, 2015 - 8:02 PM
- - Bitter   The engine light, what's the code?   Aug 28, 2015 - 8:05 PM
- - doory100   Not sure I don't have a scanner on me. I'm...   Aug 28, 2015 - 8:09 PM
- - Bitter   Don't guess, there could be a code set for the...   Aug 28, 2015 - 9:28 PM
- - doory100   I will look into that asap   Aug 28, 2015 - 9:32 PM
- - Box   http://www.6gc.net/howto/determine_check_engine_li...   Aug 28, 2015 - 9:59 PM
- - doory100   Code: 25 and 31   Aug 29, 2015 - 7:28 AM
- - Box   25 is air/fuel ratio lean and 31 is air flow meter...   Aug 29, 2015 - 8:17 AM
- - doory100   Ok I did the test where you clear the code and the...   Aug 29, 2015 - 8:27 AM
- - Bitter   Whats your fuel pressure?   Aug 29, 2015 - 10:20 AM
- - doory100   I haven't checked the fuel pressure yet I have...   Aug 29, 2015 - 10:36 AM
- - Bitter   Not that I'm aware of. What's the MAP sens...   Aug 29, 2015 - 11:27 AM
- - doory100   Wouldn't turning the corrections off on the sa...   Aug 29, 2015 - 11:40 AM
- - Bitter   It should, unless there's something wrong or s...   Aug 29, 2015 - 12:18 PM
- - doory100   The settings are right and I hooked it up myself. ...   Aug 29, 2015 - 1:08 PM
- - Bitter   It SHOULD be doing nothing at idle, AFC's are ...   Aug 29, 2015 - 1:27 PM
- - doory100   So their is two connectors on the Celica TB and th...   Aug 29, 2015 - 3:04 PM
- - Bitter   Post a photo of the part in question.   Aug 29, 2015 - 3:16 PM
- - doory100   RE: Help!! Celica is runnig rich at idle   Aug 29, 2015 - 3:31 PM
- - Bitter   That's the idle speed motor, it controls the i...   Aug 29, 2015 - 3:32 PM
- - doory100   So it would be okay if it wasn't plugged in be...   Aug 29, 2015 - 3:36 PM
- - Bitter   Can you bolt on an original 5S throttle body and p...   Aug 29, 2015 - 4:25 PM
- - doory100   No, not with out removing the new intake manifold ...   Aug 29, 2015 - 6:47 PM
- - Bitter   It sounds like the throttle body is the problem th...   Aug 29, 2015 - 6:51 PM
|- - doory100   QUOTE (Bitter @ Aug 29, 2015 - 7:51 ...   Aug 29, 2015 - 6:53 PM
- - Bitter   Maybe, what's the MAP sensor reading at idle a...   Aug 29, 2015 - 7:00 PM
- - doory100   drove the car back to the shop today. I needed my ...   Aug 29, 2015 - 7:10 PM
- - Smaay   wait a minute. what engine are you using and what...   Aug 30, 2015 - 10:08 AM
- - doory100   5sfe with a custom intake manifold and a 1mz v6 C...   Aug 30, 2015 - 10:29 AM
- - Bitter   The MAP sensor is in the picture, top left on the ...   Aug 30, 2015 - 10:33 AM
- - doory100   Here is the new TB with the idle speed motor on it...   Aug 30, 2015 - 11:53 AM
- - Bitter   That's the idle speed control motor and valve,...   Aug 30, 2015 - 1:24 PM
- - doory100   I am going to install the new TB today. I'm th...   Aug 31, 2015 - 7:08 AM
- - doory100   So installed the new TB and its still running rich...   Aug 31, 2015 - 7:00 PM
- - Bitter   Uh you need the MAP connected to manifold vaccum, ...   Aug 31, 2015 - 9:45 PM
- - doory100   I have an idea. I just rebuilt a engine by myself ...   Sep 1, 2015 - 5:04 AM
- - doory100   so after putting the map vacume line into the TB, ...   Sep 1, 2015 - 4:20 PM
- - Bitter   I'm not familiar with the Neo, I had a SAFC2 t...   Sep 1, 2015 - 6:45 PM
- - doory100   I used a T fitting like you said at the end of the...   Sep 1, 2015 - 6:55 PM
- - Bitter   Ok, is the MAP sensor reading steady or does it do...   Sep 1, 2015 - 6:58 PM
- - doory100   Seems to be fine. Drives like it did before.   Sep 1, 2015 - 7:40 PM
- - Bitter   You had the dead spot before too?   Sep 1, 2015 - 8:11 PM
- - doory100   No I'm not sure if it's still there I thin...   Sep 1, 2015 - 8:25 PM
- - doory100   blew the rad!! I hope I didn't damage ...   Sep 5, 2015 - 6:51 AM
- - doory100   Are there any other Toyota's that share the sa...   Sep 5, 2015 - 6:20 PM
Lo-Fi Version Time is now: August 29th, 2026 - 3:55 PM
