Jan 29, 2003 - 4:36 AM
Enthusiast ![]() ![]() Joined Jan 29, '03 From San Diego, CA Currently Offline Reputation: 0 (0%) |
I just bought new snake eyes white led windshield nozzle lights for my 94st and would like to put it on a switch located near my shifter. Any ideas on how i can do that?
-------------------- Chris Malaqui
Non-running Celica |
Jan 29, 2003 - 7:08 AM
Enthusiast ![]() ![]() ![]() Joined Sep 27, '02 From UK Currently Offline Reputation: 1 (100%) |
Not sure whether or not this will help ...
I wired mine to a 2-position on/off illuminated switch and took the power and earth sources from the cigarette lighter. I put the switch in the panel below the steering wheel next to the fuse cover. If you need more details let me know. (BTW: This is on a 97 ST - but the principle will be the same) |
Jan 29, 2003 - 3:57 PM
i already use that line for my glo pedals and stuck the switch where the lighter use to be. would it be possible to wire them together on the same switch? And are the white led legal in CAlifornia
This post has been edited by KiLisStalker: Jan 29, 2003 - 3:58 PM -------------------- Chris Malaqui
Jan 29, 2003 - 4:09 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) |
yep u can put it on the same switch
Jan 29, 2003 - 9:50 PM
![]() Enthusiast ![]() Joined Sep 4, '02 From Meridian, MS Currently Offline Reputation: 0 (0%) |
Are you sure you want to put those things on your car??
Jan 31, 2003 - 4:35 AM
I'm not sure about the legaility of them.
I know here in France it's illegal to use them on a public road. Having said that, the police are pretty laid back about that sort of thing here. As for wiring the nozzle lights... Depends what you want to do. If you want the glo pedals and nozzle lights on at the same time then you can use and wire into the same switch. If you want the glo pedals and nozzle lights on independently or at the same time then you can use the same wires and wire in another switch. If you want the glo pedals and nozzle lights on just independently then just change the switch to a 4-pin, 3-position one. (pos.1-up-glo pedals, pos.2-middle-off, pos.3-down-nozzle lights). |
Jan 31, 2003 - 4:02 PM
Thanks i'll put it on the same switch.
Feb 4, 2003 - 11:51 PM
Enthusiast ![]() Joined Sep 28, '02 From Lancaster Ca Currently Offline Reputation: 0 (0%) |
they are not legal, the only lights allowed to illument to the front of your car are the head lights and running lights, also fog lamps, if you get blue its an even bigger fine because only police are allowed to ahve and blue comming from their car, my friends dads a chp
| Lo-Fi Version | Time is now: June 12th, 2026 - 10:18 AM |
