Sep 3, 2015 - 10:52 PM
I decided to create a thread on its own, because maybe i can get some guidance. No I dont want "take it to the shop" even my dog can tell me that.
so i ordered a kit ![]() and everything was fine and dandy, going cool!! ![]() ![]() until I saw, that there is no space underneath !!! lol. I cannot, and will not build equal length y pipe, its impossible, unless i delete the crossmember, and find a new way to support engine, and thats more complicated. lol ![]() the rear bank, is almost but not impossible to get the pipe goin. All this because im Using the headers from Gouky. Now i have the original headers from the highlander, but not sure if would clear the rack, or shifting cables, which this one does... hate to think, that i have to use a y pipe type method or even a T type. At this time, anything to hook up the exhaust. Most mandrel bent turns are not coming in a tight radius, and i dont have space. I tried to run two pipes, but there is no space. and if im not careful, ill be scraping the floor. any ideas or suggestions... This post has been edited by njccmd2002: Sep 7, 2015 - 8:36 PM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Sep 4, 2015 - 4:08 AM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
Have a look at how a Toyota Blade Master has it? (They were/are sold in Japan, they are about the size of a Allex/Runx Corolla with the 2GR-FE) since they are fairly small it might give you some ideas?
Sep 4, 2015 - 6:44 AM
![]() Don't have room for something OEM like that? Not the best I know but better than nothing. -------------------- |
Sep 4, 2015 - 7:56 AM
Open headers /thread
Sep 4, 2015 - 12:14 PM
I saw the camry picture. Remember we have a crossbar. Im off moday. Might be a chance ill end up selling the headers.
Sep 4, 2015 - 12:53 PM
Fine, ignore my ingenious solution. A picture showing, well, the whole picture would help. You might be able to notch the brace, or if you have to cut through it for the piping you might could extend the bracing out to add back support.
This post has been edited by Box: Sep 4, 2015 - 12:54 PM -------------------- 2001 Miata LS 5-speed
Sep 4, 2015 - 5:23 PM
![]() I know it's not a Celica (it's an MR2). -------------------- |
Sep 4, 2015 - 6:10 PM
that looks doable. wish i can replicate curve
Sep 4, 2015 - 6:26 PM
Oval pipe?
Sep 5, 2015 - 1:03 AM
Enthusiast ![]() Joined Dec 27, '11 From minnesota Currently Offline Reputation: 0 (0%) |
How I did my pipes. The pipe is the lowest point of the car, luckily it also moves on the same plane as the wheels. I have not scratched it yet.
This post has been edited by rdyzz: Sep 5, 2015 - 1:10 AM |
Sep 5, 2015 - 1:40 AM
lol. same issue here. low, points. how much distance between floor to the oil pan
Sep 6, 2015 - 10:17 AM
Here is a 4x4 I used to show the amount of clearence. I think on mine I mounted it lower than normal since I made all custom mounts, not having much to start off with.
This post has been edited by rdyzz: Sep 6, 2015 - 10:23 AM |
Sep 6, 2015 - 6:50 PM
Enthusiast Joined Nov 30, '12 From San Antonio Currently Offline Reputation: 0 (0%) |
Can you cut some off the end of the rear header, and wrap it over the top of the axle?
Sep 6, 2015 - 6:56 PM
Idk how much vaccuum and water hoses you got, but you might could re-rout/extend those to give you more clearance to run that "loop" over the axle/tranny.
Sep 7, 2015 - 8:35 PM
Lol. No space. This is very tight. 2gr is a monster. The performance gods will not be happy. Oh well. Best i could with the space available. Ran out of argon. Will finish tomorrow....
![]() ![]() Ill revisit in a few months something better. For now this will have to do -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Sep 22, 2015 - 5:53 PM
Well... Its done. Tested for leaks. But wont be sure after a few miles of use. Painted silver for that purpose and to protect them welds. High heat paint
Tacked ![]() All finished and waiting to be installed... ![]()
Sep 22, 2015 - 9:07 PM
Doesn't look bad at all.
What size piping ? The flanges are 2 1/4 right ? -------------------- |
Sep 22, 2015 - 10:06 PM
Yes 2 1/4. And darn forgot to add the 02 bungs lol!!! Tomorrow.... Arghh
Sep 22, 2015 - 11:10 PM
You don't need those. Fuel trims are for chumps.
Sep 23, 2015 - 10:30 AM
lol
| Lo-Fi Version | Time is now: September 13th, 2026 - 1:44 PM |
