> Compression Test
post Oct 9, 2015 - 6:07 PM
trdproven
Joined Aug 2, '05
From Guam
Guys did a compression test and got readings of 196-205 across the board. I know a lot of numbers vary and sometimes on older engines as long as they are fairly uniform it's ok. If these are considered high readings my thoughts might be to oil seepage/carbon buildup. Your thoughts since these are older engines.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 9, 2015 - 7:58 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Any reason for the compression test or just checking? You could try running a high PEA injector cleaner like Gumout 2x for a couple tanks of gas and then do a piston soak with some solvents and recheck compression.
post Oct 10, 2015 - 2:29 AM
trdproven
Joined Aug 2, '05
From Guam
Just checking... I was thinking about a top rebuild. So are those numbers ok since its uniform?
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 10, 2015 - 7:31 AM
Box
Joined Feb 23, '12
From Warrior, AL
Most engines since the late 80's should be in the 180-200 ballpark, I remember reading on the 7A Toyota had 180 as nominal and then within some 10% or so as acceptable. I'd imagine the 5S wouldn't be much different.
2001 Miata LS 5-speed
Lo-Fi Version Time is now: September 15th, 2026 - 11:43 AM
