> cluster st205, uk st205 cluster with mph fit st204
post Oct 15, 2015 - 12:52 PM
chacha
Joined Dec 29, '05
From So-Cal
i tried searching and googling if there was a direct clear answer and i couldn't find it so im asking on this forum.
Will the st205 uk spec gt4 cluster with the mph work as a plug and play in the st204 (3sgte swap st205 jdm harness)? let me know if there is any confusion. i have the jdm motor but want to use the uk spec cluster with the mph (very limited in uk that has this originally equipped to the st205 that came to the UK) with my jdm or st204 harness.
(SORRY OP, placed in the wrong section, this goes into the electrical section, please help move this topic)
This post has been edited by chacha: Oct 15, 2015 - 12:53 PM
Replies (1 - 1)
post Oct 16, 2015 - 4:22 AM
The_enD
Joined Apr 12, '13
If you swap just the mechanisms, without the body it may work. As the green board on the back is different in all the models and you might get things like oil warning when you open the door.
Lo-Fi Version Time is now: August 27th, 2026 - 1:52 AM
