> 3sgte in 79 Corolla- turbo advice, 3sgte in 79 Corolla- turbo advice
post Dec 13, 2015 - 9:12 PM
Rich12
Joined Dec 13, '15
From New Zealand
Hi,
I am building a 1979 Toyota Corolla Sr Coupe with a gen 2 3sgte in it. Things that I have done to date on the engine include: Oil return lines from the head as it sits vertically, oil pick up and sump modifications, new intake plenum, new top mount exhaust manifold, big top mounted fuel rail, currently have 565cc injectors, front mounted intercooler, Link G4 Storm computer, drop tank in the rear with surge tank, bigger fuel pump, and a couple other small bits and pieces.
Car will be mainly for street, with some track days here and there.
I have got this far and am now looking at the ct26 turbo and thinking I should get something a little better. My power goals are as much as possible (so around 300rwhp from what I have read) without opening up the engine and spending large amounts of $$ putting in forged components- not yet anyway.
So my question is where do you recommend I go with the turbo? I dont have thousands to fork out for something special at the moment so am thinking of making an OEM turbo work. Im currently considering a td05 off of an evo 3. Its cheap, apparently goes very well and can be upgraded. Wanted a twin scroll evo 4+ turbo but getting one to mount up would be a nightmare. TD05 the right track or maybe a td06?
Cant get my hands on a ct20b- never even seen one for sale, so please dont suggest that.
I am yet to make a downpipe and my exhaust manifold can be modified- so not to worried about different flanges etc..
Thanks
Replies (1 - 10)
post Dec 14, 2015 - 11:28 AM
Ooohh. Post some pictures. I had a car that had a 3s that i parted. It had an evo turbo. I did not build it.
post Dec 14, 2015 - 3:30 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
20b is more common than you think, just look for it.
if you want 300 with quick spool, get a GT28RS. get the adapter from the stock manifold to a T-3 from KO racing. of course you will need a custom FMIC setup.
and yes, please post pictures of your modifications to the oil pan and pickup. I was thinking of putting a 3rd Gen 3S-GTE in my 4Runner
BTW what transmission are you going to use?
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Dec 15, 2015 - 4:00 AM
Rich12
Joined Dec 13, '15
From New Zealand
Ive got a w58 gearbox with a modified bell housing and short shift kit, big custom made driveshaft and a G series hilux lsd diff in the rear with soon to have torsion and pan hard bars.
Will put some pics up of my oil pan and pick up when I get round to taking the pan off again. In the pics you can see the oil return from the head, inside and out.
I would like more than 300hp at the wheels if the internals are up to it? All the mods Im doing now are with the intention of handling more power later on.
Currently looking at getting an evo 8 mr turbo. Cheap and good from what I have read. Thoughts?
Dont have the money right now for a fancy expensive turbo so thinking a good oem one for now will do.
Evolution MR aka "8.5" turbo
GSR = TD05HRA-16G6-10.5T (Ti Alloy option)
Nozzle Area (cm2) = 10.5
Compressor = Aluminium, 68mm wide
Any other tips or tricks you guys may have for me to apply to my engine?
Hope the photos work.
That intake plenum in the photos is my old one. New one will be better.
https://drive.google.com/file/d/0B2la2i1AuS...iew?usp=sharing[/img]
post Dec 20, 2015 - 1:36 AM
nsxtypeR
Joined Jan 3, '06
From The Netherlands
Ct20b's are easily available in the UK. If you want a bit better and still want oem fit you could go for a turbotechnics s148 (hybrid ct20)
JDM ST205
post Dec 23, 2015 - 2:15 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
I wouldnt use a W58. If you can find an R154 go that route.
post Jan 15, 2016 - 1:03 AM
Rich12
Joined Dec 13, '15
From New Zealand
Why not the w58?
post Jan 15, 2016 - 7:40 AM
richee3
Joined Jun 29, '08
From Denver
QUOTE (Rich12 @ Jan 15, 2016 - 12:03 AM) *
Why not the w58?
The W58 is a weak transmission whereas the R154 is much stronger. I've heard of stock IS300's destroying W58's when the driver wasn't even pushing the car. Of course, that's a more extreme example and they won't all break quite that easily.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 17, 2016 - 1:48 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
W58's are not that weak, they came in the MKIV non turbo 5 speeds. they can support 400 HP
post Jan 17, 2016 - 6:16 PM
Rich12
Joined Dec 13, '15
From New Zealand
Ive already had a driveshaft made to fit the car with the w58. I was also under the impression that being such a light car, the gearbox would be under less load?
post Jan 23, 2016 - 12:10 AM
wont know until you try. but most likely it will take some abuse.
Lo-Fi Version Time is now: July 11th, 2026 - 6:18 PM
