Dec 15, 2015 - 11:18 AM
Enthusiast ![]() Joined Aug 25, '15 Currently Offline Reputation: 0 (0%) |
Driving home from work the other day the car made a strange noise, possibly a backfire or something then started running real rough. A minute later the CEL came on (P0302). I did a tuneup, new plugs, wires, cap/rotor and if anything it ran worse. There was a small amount of oil in the distributor housing but nothing significant. Thanks to Richee3 for helping me continue troubleshoot we confirmed that we had spark on cylinder two, and the car ran the same with or without that plug wire connected. I then ran it for a minute with cylinder two plug removed to see if it was getting fuel. It seemed like it wasn't, so Richee3 kindly sent me an OEM fuel injector (plus some sweet chrome door strikers). Last night I swapped the injector and also replaced the valve cover gasket, spark plug tube gaskets, PCV valve and grommet. Unfortunately this hasn't helped the issue, it runs even rougher now and I can barely get it to idle for more than a second or two. I'm running out of ideas and may have to bite the bullet and get it towed to the shop. I thought I'd check here before doing that in a day or two. Any other thoughts on what could cause the issue?
CosaChow 5SFE suddenly running rough Dec 15, 2015 - 11:18 AM
RocketScott Might have jumped a tooth on the timing belt?
I... Dec 15, 2015 - 8:20 PM
94yotaGT Eh when I got my celica it was a tooth or two out ... Dec 15, 2015 - 10:50 PM
CosaChow I did some more work and got it going tonight... Dec 15, 2015 - 11:34 PM
Smaay did you ever check the code?
chances are the ECU ... Dec 16, 2015 - 8:55 AM
CosaChow The original code was a P0302 but I didn't che... Dec 16, 2015 - 9:45 AM
94yotaGT Not sure what year your Celi is, but if it is like... Dec 16, 2015 - 3:54 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 14th, 2026 - 7:38 AM |
