Jan 8, 2016 - 1:19 PM
Enthusiast ![]() ![]() ![]() Joined May 10, '14 From Tulsa, OK Currently Offline Reputation: 5 (100%) |
Hello: After installing the header and getting it all set, I am getting these two codes. I reset them once and these two come back again. I will check for leaks etc and the reading on the first O2 sensor (7aFE engine stock, 1996 ST HB). What else I need to look for?
How do I check for sensor circuit heater? thanks in advance. This post has been edited by msk59: Jan 8, 2016 - 1:25 PM |
msk59 Code P0130 adn p0133 Jan 8, 2016 - 1:19 PM
Smaay did you put the O2 sensors back in?
did you swap ... Jan 8, 2016 - 2:39 PM
msk59 QUOTE (Smaay @ Jan 8, 2016 - 1:39 PM... Jan 9, 2016 - 10:35 AM
igpx12 Might just be a faulty sensor or it might have a b... Jan 9, 2016 - 12:59 AM
igpx12 Oh, well if you have the system open ended like th... Jan 9, 2016 - 3:26 PM
msk59 Not sure I understand what you are saying. The dow... Jan 9, 2016 - 4:35 PM
Jmk91 What he was meaning was that if you had an open ex... Jan 9, 2016 - 5:22 PM
msk59 Thank You. I pulled the header out and notice the ... Jan 10, 2016 - 7:26 PM
Jmk91 The junk gaskets they give you always leak. I had ... Jan 10, 2016 - 10:43 PM
msk59 You are so right about the junk gasket and this wh... Jan 10, 2016 - 11:54 PM
msk59 Hello Guys: I am facing a new issue. After I disco... Jan 14, 2016 - 8:53 AM
cheela just buy the material and make your own.
do you st... Jan 14, 2016 - 9:34 AM
igpx12 Here is what you want, it will fit with that style... Jan 14, 2016 - 10:01 AM
msk59 Cheela: Thanks that was my second option.
Igpx12... Jan 14, 2016 - 10:35 AM
msk59 OK after several gaskets I finally had to replace ... Mar 4, 2016 - 3:53 PM
igpx12 Replacing the O2 would be your best bet, clearing ... Mar 4, 2016 - 8:24 PM
msk59 thanks I plan on replacing the O2 sensor after i c... Mar 5, 2016 - 10:36 AM
Bitter Most time heater circuit codes are just bad heater... Mar 5, 2016 - 10:51 AM
msk59 OK I will try that and see what happens. I found p... Mar 5, 2016 - 11:55 AM
Bitter I prefer the 'direct fit' so they just plu... Mar 5, 2016 - 12:15 PM
msk59 Thanks, I think it is direct fit as I checked the ... Mar 5, 2016 - 12:51 PM
igpx12 QUOTE (msk59 @ Mar 5, 2016 - 12:51 P... Mar 6, 2016 - 11:25 AM
msk59 Update: Installed the new O2 Sensor last night. dr... Mar 15, 2016 - 7:42 AM
msk59 Ok the light is back ON after installing the new O... Mar 16, 2016 - 8:59 AM
Bitter Same codes? Mar 17, 2016 - 8:13 PM
msk59 Sorry Bitter for the delayed response. I was TDY. ... Mar 21, 2016 - 7:09 AM![]() ![]() |
| Lo-Fi Version | Time is now: September 11th, 2026 - 7:18 AM |
