Jan 13, 2016 - 7:14 PM
Enthusiast ![]() Joined Jan 22, '14 From South Yorkshire, UK Currently Offline Reputation: 0 (0%) |
Been a while since I've been on, basically because I've had 26000 trouble free miles.
This week though, had a bit of an issue turning when engine starts. A bit of chirping from the engine bay accompanied this. Then, catastrophe. Leaving work, lost all power steering, heater started blowing cold, rad was boiling after a ten minute emergency drive back home at night, accompanied by battery discharge light and brake warning light, which I assume means brake servo is not running (does it feed off P/S pump?), although I noticed no drop in braking performance. The lack of heat almost seems like head gasket, although I'm wondering if it's a belt issue due to the chirping, and I assume it runs past the alternator and PS pump. Any input would be massively appreciated. |
englishdas Help needed urgently! No P/S, Heat/ battery discharging Jan 13, 2016 - 7:14 PM
englishdas jeez, do I feel like an idiot. Belt shredded. Shou... Jan 14, 2016 - 10:08 AM![]() ![]() |
| Lo-Fi Version | Time is now: May 8th, 2026 - 1:09 AM |
