> Tranny Question
post Feb 18, 2004 - 7:19 PM
CBawlla
Joined Jan 28, '04
From Hawaii
When I shift into 3rd gear there's a noise that sounds like it's grinding. Also, I can put it into 3rd gear without using the clutch. This only happens with 3rd gear though. I've checked my transmission fluid and its good. Any idea what's wrong?
Replies (1 - 8)
post Feb 18, 2004 - 7:26 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
well, first of all, dont shift without clutch, it can be done with our cars, but, don't. it bad. and I think you might want to check your gearbox oil drained. they do it at places where you get your oilchanged, there are some little metal shavings that might be causing this, if I'm wrong, please someone correct me
good luck
post Feb 18, 2004 - 7:28 PM
CBawlla
Joined Jan 28, '04
From Hawaii
QUOTE (jayi12-15psi @ Feb 19, 2004 - 12:26 AM)
good luck
I didnt shift without the clutch into 3rd intentionally. I was in second resting my hand on the shifter and I guess I applied a little pressure and it just went in.
post Feb 18, 2004 - 7:34 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
ok... all I was saying, is try not to do it again. I've heard of doing that during a race, but its just not practical, to do it often.
post Feb 18, 2004 - 7:36 PM
CBawlla
Joined Jan 28, '04
From Hawaii
QUOTE (jayi12-15psi @ Feb 19, 2004 - 12:34 AM)
Alright thanks man. It's weird though how I dont have to use the clutch for only that gear and how it makes those grinding noises...
post Feb 18, 2004 - 10:36 PM
drdos
Joined Aug 19, '03
From Buffalo,NY
does it sould like almost a whilsting noise? If so i had the same problem the gear look leaked from the car.
post Feb 19, 2004 - 1:00 AM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
if it's a grinding noise... and it's there if you use the clutch or not... then you're syncro's are going out... probably due to you not using your clutch... my syncro's went out in my tranny and it had to be replaced....
toyota is known for having syncro's go out
post Feb 19, 2004 - 1:25 AM
acidbyte7
Joined Jan 20, '04
From princeton, new jersey
what you did into 3rd is power shifting....theres a point of slip inbetween all gears and like you said if you apply slight pressure to the shift knob and that point comes around you can pull it out and throw it into next gear...my friend does it when he's racing....i still don't know how he gets into into the next gear with our grinding....but the only time he ever uses the clutch is in 1st and reverse h's been doin it for about two years now....i'm totally boggeled by the fact
post Feb 19, 2004 - 2:05 AM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
QUOTE (acidbyte7 @ Feb 19, 2004 - 6:25 AM)
you can pull out of gear w/o using the clutch at any point...... he slipped it INTO gear w/o using the clutch.... different story entirely
Lo-Fi Version Time is now: September 14th, 2026 - 3:28 AM
