> Swapping in a 4th 3sgte soon, Need advice on what's needed to be done before dropping in
post Jan 29, 2016 - 3:48 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
I'm planning on swapping in a 4th gen 3sgte and want to know what's recommended to be swapped or replaced or repaired while the engine is still out? Is the waterpump interchangeable with the 5sfe? Should I replace the oil pump seal and pulley seal? I know they're a common leak on a 5sfe. Here's the list I've made talking to a friend of mine with a st184 4th gen swap.
Interchangeable with 2nd gen
Front main seal #90311A0005
Rear main seal #9008031073
Alternator belt #909160229377
Power steering #99363-70760-83
Cam seals #9031135040
Injector Seals – 2zzge - 9030107024
Timing Belt – 3rd gen - 13568-79105
Wire - Wiregap
Clutch Kit – SouthBend
Oil – 10w30
Spark Plug – NGK Iridium BKR7EIX
Lo-Fi Version Time is now: June 9th, 2026 - 4:48 PM
