> Engine mounts
post Mar 6, 2016 - 4:33 AM
Kronustor
Joined Mar 6, '16
From Avenal, CA
Hey guys new celica owner trying to get my car into running condition. The front and rear motor mounts are bad and I'm having a problem with the rear mount. I have it unboled but when I try to remove it hits on the rack and pinion. I read that I may need to unbolbolted the suffrage to to get it out. Any suggestions would be appreciated.
The car is a 1994 gt with a manual transmission.
post Mar 6, 2016 - 8:56 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
yeah you might have to drop the K rail. with both the front and rear unbolted, you should be able to rock the engine enough to swap them out
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Mar 7, 2016 - 7:09 PM
csscza
Joined Apr 28, '10
From Ft Worth
I jacked the engine up a little to get to mine.
post Mar 9, 2016 - 10:25 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Do a search, there's a huge thread on this that even has a video on how to get it out
My Celica!
post Mar 16, 2016 - 8:07 PM
pandito
Joined Apr 15, '15
From California
I've been waiting until the weather got better to attempt mine, but from what I've seen / read, the EASIEST way is to remove 1 or 3 bolts from the cross beam underneath (subframe?) that's covering the rear mount and swing it out of the way.
Here's a vid this guy did a while back. I'll take a look and see if I can locate the other really good vid I saw a while back. If you can take, vids for the rest of us who are going to do this. Pleeeaasseee.
post Mar 21, 2016 - 12:26 PM
Kronustor
Joined Mar 6, '16
From Avenal, CA
Sorry for not replying guys, I thought I would get a notification when people replied but never got one. I ended up removing the bracket on the engine itself and the mount came off easily after that. My problem now is that I spun a bearing somehow and now my car is dead.
I don't know if I should start a new post but does anyone know if the 5sfe from a 1992 will swap into the 1994? It's supposed to be the same engine and their both on obd1 so I'd assume they fit. A guy crashed his and is selling the whole car for 600 so I want to use that to bring my car back alive.
post Mar 21, 2016 - 9:55 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
the 5th gen celica has an older 5S in it. I wouldnt go backwards
post Apr 12, 2016 - 1:56 AM
trdproven
Joined Aug 2, '05
From Guam
i think the older 92 does not have knock sensor huh smaay?
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 14, 2016 - 11:44 PM
VavAlephVav
Joined Dec 3, '13
From Missourah
yeah, I put two jacks one under the motor and one under the transaxle so that I could remove the center member the motor mounts attach to. You'll want to get the car up in the air as high as your jackstands will get you. And even then its still a real bitch.
Bust a Deal; Face the Wheel.
Lo-Fi Version Time is now: June 21st, 2026 - 5:00 AM
