Aug 21, 2017 - 6:21 PM
Enthusiast ![]() ![]() Joined Apr 7, '15 From New Mexico Currently Offline Reputation: 0 (0%) |
Now that I am switched over to a water to air intercooler I decided to build a cold air intake to battle intercooler heat soak. I noticed that when I am at idle for a long time with the intercooler fan off that the intercooler water temps will climb from mid 90s to 110+. I did not feel like paying $200 or more for some company's cold intake set up so I built my own. I had some extra couplers laying around, some 3 inch intercooler pipe, and kept the existing cone filter.
![]() And here is a shot with the water guard on the filter. I can't have my 3s getting hydro-locked.
Aug 21, 2017 - 7:23 PM
To me it's silly to spend what it costs on a big name brand kit, especially whens gains are usually negligible. Just make your own since piping is piping and couplers are couplers, then top it off with a name brand filter.
Aug 21, 2017 - 9:05 PM
To me it's silly to spend what it costs on a big name brand kit, especially whens gains are usually negligible. Just make your own since piping is piping and couplers are couplers, then top it off with a name brand filter. $200-300 for and advertised 5-10 hp gain is not worth it. I built this one for about $50. |
Aug 21, 2017 - 9:18 PM
Exactly. I think it cost me like $70 for piping, couplers, and an AEM filter vs almost $300 for a K&N or SLP cold air intake. Yeah it took some more fiddling with I'm sure, but worth saving $200+ for probably the exact same end result.
Aug 21, 2017 - 9:23 PM
I was able to find another CT15B for my 4th gen 3sgte. I was looking for one so I could get it rebuilt and upgraded without taking the car down for a few weeks during track season. I just got it in today.
![]() ![]() I am planning to send it off to ATS Racing to get the "Sweet ct16" done to it. I am pretty excited! My concern is the wastegate. The problem with the stock wastegate is that when I get on it the boost will shoot 1-3 psi past the target then settles in at the boost level I am shooting for. There is no way to adjust the OEM wastegate, it is sealed shut, does not have an adjustable actuating arm, and it is welded to the bracket. ![]() ATS offers a billet adjustable wastegate upgrade for an extra $200. You can chose to have a 12, 14.5, or 17 psi spring put into it. I am wondering if that is the best option because when they mean adjustable does that mean you can adjust the actuating arm or does it mean you can swap springs? Is it a 1 or 2 port wastegate? If I go that route I plan to get the 12 psi one but I am a little uncomfortable with my base pressure being 12 psi. It will make it hard for me to set up boost by gear when I go standalone with that high of a starting boost level. Is there an option to go with a Turbosmart 2 port wastegate? Then I could have a low base pressure and with a 4 port boost controller. Then I can multiply that by up to 4 times and get my boost extremely acurate. Which Turbosmart model would I need? Which bracket would I need for it? I am planning to e-mail a bunch of these questions to ATS but I welcome any of your thoughts. This post has been edited by HardHead93: Aug 21, 2017 - 9:28 PM |
Aug 23, 2017 - 1:19 PM
I got the side skirts installed on the car. It really improves the look.
![]() This thread really helped me to install them. http://www.6gc.net/forums/index.php?showtopic=37670 Too bad Photobucket has messed up the photos. |
Aug 23, 2017 - 3:37 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
verts definitely look alot better with sideskirts on. looks great!
-------------------- ![]() *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Aug 23, 2017 - 4:23 PM
Now it needs rear splitters to finish the look.
Aug 23, 2017 - 4:33 PM
Aug 23, 2017 - 6:00 PM
You'll have to get ones for the Curren.
Aug 26, 2017 - 9:58 AM
What about also having the intercooler fan RPM based so when the engine drops to low speeds near or at idle the fan turns on to prevent heat soak from even starting, in addition to a temperature control.
Sep 8, 2017 - 7:59 PM
I am doing a conversion of my front headlights over to LED. These halogen bulbs are not cutting it! They are definitely too dim when compared to a lot of the newer car's headlights. I went with the Auxbeam brand and they look great.
![]() Right now I only have the headlights on LEDs but I am trying to find a good LED that will fit into the fog light housing. The only issue I had with the install is I had to plug the bulb in backwards because the polarity is reversed. This post has been edited by HardHead93: Sep 8, 2017 - 8:00 PM |
Oct 8, 2017 - 12:13 PM
I replaced my bumper that I cut to s**t trying to figure out my engine heat issue. Come to find out it was not air flow but my A2A intercooler heat soaking and blocking air flow to my radiator. I decided to get another bumper that was clean with out any ducts. Check it out:
![]() I made the decision to go back to a stock looking bumper after parking next to a Supra and seeing how clean that car looked next to mine. ![]() Clean Supra vs Ricer Celica This post has been edited by HardHead93: Oct 8, 2017 - 12:14 PM |
Oct 8, 2017 - 3:43 PM
The beam on those LED conversion craps are awful, glare all over, lots of light where you don't need it or want it.
Oct 10, 2017 - 8:43 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
New bumper will look way better.
I was personally never a huge fan of the vents all over the place. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Oct 10, 2017 - 4:38 PM
I was ok with the first two on the top, didn't like the lower two. I would say going for more of a sleeper look, but then the hood ruins that vibe.
Oct 10, 2017 - 9:45 PM
I was ok with the first two on the top, didn't like the lower two. I would say going for more of a sleeper look, but then the hood ruins that vibe. I am with you. I was fine with just the one duct up top. I got too out of hand with the ducts. Here is a shot of the car with the bumper on. ![]() I got to get a photo ready for Celica of the month. |
Oct 10, 2017 - 9:49 PM
Woo, much better.
Nov 9, 2017 - 5:40 PM
Enthusiast ![]() Joined Dec 16, '16 From PEI,Canada Currently Offline Reputation: 1 (100%) |
I just went out for a little bit of spirited driving and OH MAN! This engine is crazy! what model MR2 did you find the lsd out of? -------------------- 96 ST Project
09 Corolla-daily Instagram: Janson1745 ![]() |
Nov 10, 2017 - 10:43 PM
I just went out for a little bit of spirited driving and OH MAN! This engine is crazy! what model MR2 did you find the lsd out of? It is out of the MR2 Spyder or Lotus. Here is an ebay link for one: https://www.ebay.com/itm/Toyota-Helical-Lim...q8S&vxp=mtr It drops right into the S54 transmission. Just make sure you swap the speedo gear from you stock diff. I forgot to do that and my speedometer read the wrong speed. I had a transmission shop do the swap because there are some specialized tools needed for taking the tranny completely apart and putting it back together. |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 9:08 AM |
