> Hey all, passenger side motor mount question
post May 2, 2016 - 1:12 PM
celica91gts
Joined May 2, '16
From Tucson, AZ
hey everybody,
i'm a 5th gen owner currently swapping in a st215 motor and i had an issue with my passenger side motor mount.
this old thread i found perfectly describes my problem,
http://www.6gc.net/forums/index.php?showtopic=68361
this is my current thread on celicatech.
http://www.celicatech.com/forums/showthrea...72#post30251672
as you can see in this picture of where a 6th gen mounts
and a picture of where my 5th gen mounts. the chassis is a little different but because of this i can't use a 6th gen mount
do you guys know of anything i can do? or do i need to have a custom motor mount made?
Replies (1 - 3)
post May 3, 2016 - 6:47 AM
Seems like celicatech does not have an answer and i cant beleive they cant help you. Most forums are dying. Unless someone has done it before. It will be hard to get an answer here.
However i will tell you the way your engine mounts in your car is very much like the mr2 5sfe mounts. You are trying to use the mount of the 185 with the engine bracket of the 215. What happened to the original bracket that goes with the mount. Can you not bolt that bracket to the engine
post May 3, 2016 - 8:07 AM
celica91gts
Joined May 2, '16
From Tucson, AZ
no, i compared and its a different mount. So im gonna take it to a machine shop and see if they can help me. it seems like my last option. Thanks for your input thumbsup.gif
post May 3, 2016 - 11:00 AM
celica91gts
Joined May 2, '16
From Tucson, AZ
you're right though. MR2 5sfe does look a little strighter
http://www.ebay.com/itm/NEW-TOYOTA-Engine-...1tb&vxp=mtr
Lo-Fi Version Time is now: August 29th, 2026 - 3:37 PM
