May 10, 2016 - 7:40 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
This thread is now a product warning thread on the Dorman Wheel hubs for the RAV4.
I have found an issue with the Dorman 930- 419 RAV4 front wheel hubs used in the 5x100 to 5x114.3 conversion. The studs that come in these Dorman hubs have a tapered shoulder with a knurl diameter that goes from 12.46-12.60mm The OE replacement studs for a majority of Toyota vehicles is 14.20mm (Dormans listed studs for the RAV4 are 14.20) Now in the case that you dont plan on having any issue with you hub this shouldnt be a problem for you and happy swapping, but... ******** If you somehow break a stud or need a replacement for any reason, the hub either needs to be replaced or re-bored If you want extended studs from companies like ARP you will either need to re-bore the holes or (I am getting in studs tomorrow that I hope will fit and will update this) I havent looked around for a OE size stud that might be able to match the 12.6 knurl diameter maybe for some other car, that might take some time, most OE sizes seem to be above 13mm or so ******** I called Dorman to get more info and they are well aware of this issue and dont know why its being manufactured that way. Here is a pic of IS300 ARP Wheel Studs (14.17mm Knurl Diamter) Next to the Dorman Studs that came out of the wheel hub These ARP studs WOULD have fit if the hub were the spec it should be.
This post has been edited by Tigawoods: May 16, 2016 - 12:58 PM -------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Tigawoods Dorman RAV4 5x114.3 Conversion Manufacturer Issue May 10, 2016 - 7:40 AM
HectortheRican Assuming the original studs didn't stretch out... May 10, 2016 - 9:02 AM
Tigawoods yeah if 14.20-22 is already the proper spec for th... May 10, 2016 - 9:30 AM
HectortheRican QUOTE (Tigawoods @ May 10, 2016 - 8... May 10, 2016 - 2:11 PM
Tigawoods it should be somewhere around 8mm.
The OE studs ... May 10, 2016 - 2:39 PM
njccmd2002 I want curly fries May 11, 2016 - 1:48 PM
Tigawoods bump for new information May 16, 2016 - 12:50 PM
njccmd2002 unfortunately those hubs, if aftermarket, will nev... May 16, 2016 - 4:00 PM
presure2 Wait whu?? Rav4 hubs on a celica?? 5x114wha?? Seri... May 16, 2016 - 5:09 PM
Tigawoods QUOTE (njccmd2002 @ May 16, 2016 - 5... May 16, 2016 - 9:25 PM
Tigawoods So I have contacted Dorman, MOOG, Dura Intl, WJB a... May 20, 2016 - 2:14 PM
njccmd2002 But they dont have replacement studs. Have to buy... May 20, 2016 - 5:34 PM
trdproven good info, but breaking a stud is a bit rare unles... May 21, 2016 - 4:29 PM
Tigawoods QUOTE (njccmd2002 @ May 20, 2016 - 6... May 22, 2016 - 12:29 AM
trdproven I relooked at all the measurements between a camry... May 26, 2016 - 5:43 PM
Tigawoods everything else is in spec other than this stud bo... May 27, 2016 - 6:19 AM![]() ![]() |
| Lo-Fi Version | Time is now: September 1st, 2026 - 1:48 PM |
