May 23, 2016 - 6:47 AM
Enthusiast ![]() ![]() Joined Jun 30, '05 From Chattanooga, TN Currently Offline Reputation: 5 (100%) |
I have a very limited knowledge of transmissions and was hoping someone here might be able to diagnose my problem or tell me what to check.
Lately when accelerating in 4th gear, the shifter will pop into neutral. 3rd gear has always pushed itself towards neutral while accelerating, but never actually went into neutral. In 3rd or 4th gear i can hold pressure on the shift knob and feel it pull towards neutral when accelerating, then if i release the throttle, it goes back fully into gear. Recent car changes: Teaching daughter to drive a manual. there have been some rough clutch engagements lately. I recently bottomed out on a speed hump my front motor mount insert has deteriorated (haven't checked the rear mount, i had installed kirkasaurus mounts years ago) Im hoping maybe i just need to adjust the slack on a cable somewhere. Any thoughts? This post has been edited by Stu37363: May 23, 2016 - 6:49 AM |
Stu37363 Help - Car pops out of gear May 23, 2016 - 6:47 AM
Box Does it grind when downshifting into third and/or ... May 23, 2016 - 1:30 PM
Stu37363 No grinding at all when shifting. i was just under... May 23, 2016 - 1:43 PM
Box Yeah that'd be best, would suck to ruin the sy... May 23, 2016 - 4:07 PM
MScME So the hypothesis is that the drivetrain has dropp... May 24, 2016 - 2:42 AM
Stu37363 Well, just fixed the mounts. The rear mount was re... May 27, 2016 - 8:41 AM
wingnight11 Did you figure it out? I'm having the same iss... Sep 4, 2016 - 2:43 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 29th, 2026 - 4:29 PM |
