> Midwest Summer Meet V.1 ***Locked in! 8/13***, Let's get this bish rolling
post Jun 6, 2016 - 9:08 AM
bloodMoney
Joined Aug 4, '06
From Chicagoland
WE ARE LOCKED IN! AUG. 13th @ NOON
Location: Starved Rock State Park, Lone Point shelter off of rt. 71. For any newcomers, please note that the shelter is not actually located inside Starved Rock State Park.
GPS coordinates: 41.31084, -88.939776
https://www.google.com/maps/@41.31084,-88.9...#33;3m1!1e3
What's it looking like guys? Sometime in July?
Discuss.
This post has been edited by bloodMoney: Jul 18, 2016 - 10:34 AM
~bloodMoney
7 Pages V   1 2 3 > »
Replies (1 - 19)
post Jun 6, 2016 - 11:46 AM
cheela
Joined Feb 2, '07
From Berlin, WI
early and mid July will work for me. Towards the end of July I will be busy moving my celicas into my new home. smile.gif
post Jun 6, 2016 - 2:44 PM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
Im good for July as long as its not the 9/10th (EDIT!! had my weekends wrong!)
July 16th would be the only weekend I could make it.
This post has been edited by 4-eyed-freek: Jun 6, 2016 - 10:37 PM
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
post Jun 6, 2016 - 3:45 PM
enderswift
Joined Jul 12, '08
I say July 9th
post Jun 7, 2016 - 8:03 AM
narly_charley
Joined Sep 1, '09
From Marengo, IL
I'm off on the weekends, so I'll try to make whatever work. c:
2000 GT-S 6 SPD... SOLD!
post Jun 8, 2016 - 8:07 AM
narly_charley
Joined Sep 1, '09
From Marengo, IL
Figured I'd share my continuing wheel Corolla wheel bearing story with you guys. A month ago I put my FOURTH wheel bearing (put an OEM bearing and hub in). This one has my father and I scratching our heads... We've checked bad grounds already. We're going to replace the bearing for the fifth time and put a ground from the battery to the starter bolt... It's funny, my dad's been a tech for 32 years and he's never seen a car eat bearings like this...
post Jun 8, 2016 - 8:21 AM
bloodMoney
Joined Aug 4, '06
From Chicagoland
Joe, what does the ground have to do with wheel bearings?
Also, if you are going through them so frequently, are you looking for other problems in an attempt to correct? A few off the top of my head are bad CV, wheel out of balance, deformed knuckle?
~bloodMoney
post Jun 8, 2016 - 9:37 AM
richee3
Joined Jun 29, '08
From Denver
A bad ground could let current flow through the bearing and cause pitting.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jun 8, 2016 - 1:00 PM
I would get rid of corolla
post Jun 8, 2016 - 2:48 PM
narly_charley
Joined Sep 1, '09
From Marengo, IL
I've thought about putting it into a ditch. Haha! Not really. It's in VERY good shape for 190,000 miles.
We replaced the bad ground the third time we've done it. The second bearing we changed we figured we got a bad one during the second swap. Once the third bearing went bad, we replaced the hub and bearing with good aftermarkets. We also replaced the bad ground from the body to the trans (it was literally chewed on by a mouse).
That one went bad and we figured that the hub and bearing were the issue, but far fetched. We then replaced them with a Toyota bearing and hub, and it just went bad the other day, like overnight. CV is good. The wheel is true and balanced. The knuckle being warped is unlikely, but not out of the question.
I'm going to swap the bearing out again with an OEM and put a ground from the starter to the battery. Like Daniel said, it happens... The way it got loud overnight made me think that is in fact electrical... When cranking, the arc is going across the ball bearings...
post Jun 8, 2016 - 9:12 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Just get a knee assembly from a junk yard. If you're still blowing through bearings then I dunno wtf to tell you. Maybe take the bad one apart to do a necropsy.
post Jun 9, 2016 - 7:50 AM
narly_charley
Joined Sep 1, '09
From Marengo, IL
QUOTE (Bitter @ Jun 8, 2016 - 9:12 PM) *
Are you just as confused as I am?
post Jun 9, 2016 - 4:50 PM
sixgentoyota
Joined Aug 27, '10
From 60152
Only July date we can do is 30th as of right now. August though is wide open..
post Jun 14, 2016 - 9:19 AM
narly_charley
Joined Sep 1, '09
From Marengo, IL
I questioned Chris about where he got his big pack of microfiber towels from. He said he gets his at Sams Club. I go to Costco and I looked there and bought a big 36 pack of them, they are amazing. So... If anyone needs microfibers and they have a Costco membership (or Sams), get them there. c:
post Jun 14, 2016 - 11:07 AM
bloodMoney
Joined Aug 4, '06
From Chicagoland
~bloodMoney
post Jun 16, 2016 - 10:50 AM
bloodMoney
Joined Aug 4, '06
From Chicagoland
So, what are the dates we have?
7/9 - No Skyler, No Jake/Sammy
7/16 - No Jake/Sammy
7/23 - No Skyler
7/30 - No Skyler, No Chee
Am I tracking this right?
Speak up people!
~bloodMoney
post Jun 16, 2016 - 10:55 AM
richee3
Joined Jun 29, '08
From Denver
We're out for the 16th as well.
1998 Celica GT-
BEAMS Swapped.
post Jun 16, 2016 - 5:11 PM
4-eyed-freek
Joined Apr 17, '10
QUOTE (bloodMoney @ Jun 16, 2016 - 10:50 AM) *
7/23 - No Skyler
Speak up people!
7/9 - No Skyler, No Jake/Sammy ( im def out this date)
7/23 - No Skyler (most likely can pull some strings and make this work)
7/30 - No Skyler, No Chee (most likely make this work too)
How about august???
post Jun 16, 2016 - 8:22 PM
cheela
Joined Feb 2, '07
From Berlin, WI
First weekend of august can't do. But the rest should be free.
post Jun 16, 2016 - 9:24 PM
Bitter
Joined Mar 11, '06
I can only do the dates that other people cannot do.
7 Pages V   1 2 3 > »
Lo-Fi Version Time is now: September 15th, 2026 - 2:37 AM
