> AC suction hose?
post Jun 15, 2016 - 7:43 PM
bdog_v
Joined Jan 17, '06
From Wisconsin
Hi guys solved one issue back to another mystery. I need to replace my low pressure AC hose or suction hose! I ordered one off of ebay and it is too short with the bottom end turned 180 degrees off so i can't put the bolt through and clamp the two hoses together. The one listed here:
http://www.autozone.com/cooling-heating-an.../?checkfit=true
Is exactly like the one I ordered too small and the end is wrong.
*Has anyone sourced the correct AC suction or low pressure hose coming off of the AC compressor? I need this fixed quick and it is not going that way at all....
Thanks,
Brandon
Replies (1 - 2)
post Jun 16, 2016 - 7:21 AM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Some places can build hose assemblies for you, if you have the old one or shouldn't be that much of a task.
post Jun 16, 2016 - 8:52 PM
bdog_v
Joined Jan 17, '06
From Wisconsin
I have a place that might be able to do that but I don't believe they can get new ends to crimp on that have not already been crimped (i don't believe using an old end that already has been crimped will work?) Any idea where to source new toyota style ends????/
Thanks,
Brandon
Lo-Fi Version Time is now: July 30th, 2026 - 5:06 PM
