> one of HID lights won't turn on
post Jul 16, 2016 - 9:21 AM
cellocinema
Joined Jun 10, '09
From South Korea
odd but it doesn't happen always. and when it happens, i can just turn off HID, accelerate over 3000RPMs and then turn on the headlights with no problem.
is this something to do with old battery or old alternator? i'm a bit suspicious of alternator and plan to check the amperage output if it could be a possible culprit. any opinion?
This post has been edited by cellocinema: Jul 16, 2016 - 9:22 AM
Replies (1 - 9)
post Jul 17, 2016 - 7:38 AM
trdproven
Joined Aug 2, '05
From Guam
Test parts between both sides it'll show itself
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jul 17, 2016 - 12:05 PM
cellocinema
Joined Jun 10, '09
From South Korea
not quite sure what 'parts between both sides' mean. could you clarify?
QUOTE (trdproven @ Jul 17, 2016 - 7:38 AM) *
post Jul 17, 2016 - 12:17 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
he means swap the ballasts from one side to the other to see if the problem stays with the ballast or the side of the car, then swap the bulbs one side to the other to see if the problem follows the bulb or stays on one side of the car.
post Jul 18, 2016 - 1:00 AM
cellocinema
Joined Jun 10, '09
From South Korea
thanks. i don't think it's something to do with swapping bulbs or ballasts since the problem doesn't occur only one side constantly. it's like sometimes the left doesn't turn on and the other way around other times. when i accelerate above 3000rpms i can always make the both lights functional.
QUOTE (Bitter @ Jul 17, 2016 - 1:17 PM) *
post Jul 18, 2016 - 8:33 AM
cheela
Joined Feb 2, '07
From Berlin, WI
get some Anti-Flicker Warning Cancellers and put it in. I had issues with my driver's side HID, i put one in that side and it seems to fix the problem.
post Jul 18, 2016 - 10:33 PM
trdproven
Joined Aug 2, '05
From Guam
you can also switch to AC ballasts vice DC or get a relay harness.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jul 19, 2016 - 6:51 AM
Bitter
Joined Mar 11, '06
I've read about this problem on other cars, usually it IS a voltage/amperage issue. Ballasts can take a large amount of current to start, any weak wiring along the way will act up at ballast start, since both draw off the same power source the one with shorter wiring gets power more readily and will start while the one farther away will get a weaker power and fail. Try running a heavier wire harness to the ballasts and see if that fixes it, theretrofitsource.com sells some good harnesses for cheap.
post Jul 20, 2016 - 6:51 AM
cellocinema
Joined Jun 10, '09
From South Korea
QUOTE (cheela @ Jul 18, 2016 - 8:33 AM) *
thanks. i looked into similar products, and found out they are capacitors. i already have two capacitors connected directly to battery. even in that case would it be a solution? maybe direct connection to headlights could make some difference?
post Jul 20, 2016 - 7:05 PM
trdproven
Joined Aug 2, '05
From Guam
Ac ballasts and relay harness already make the difference. Dc ballasts shoudnt even be sold.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: July 30th, 2026 - 2:56 AM
