> First post from a newbie, hope you gurus can help, Dome light circuit problems
post Aug 7, 2016 - 12:08 AM
Daz95
Joined Jul 30, '16
From Australia
Hi guys,
I'm new to the site and this is my first post, really hope you can help.
Just got a '95 SX 2.2 5 speed that's had a pretty hard life (thanks to previous owners being young boy racers - no offence to all you young boy racers).
My issue at the moment is the 'ol "no dome light" problem and I've completely gone thru all the old posts to see if any relate to my problem but no luck. The '95 I have has been messed around with over the years and has had some BAD "mods" done to it which I'm trying to correct. It's had bad head unit installs, bad alarm installs, bad amp and sub installs etc etc. I've spent the first week I've owned it removing a bunch of surplus wiring (RCA's, amp and sub power) which wasn't connected to anything but once was. In the kick panels there's evidence of former cut and spliced wiring and also some kind of fire, going by the melted plastic on the fuse and relay holders and junction boxes. Did I mention it's has a hard life??
In a nut shell there is no 12v feeding my interior lights. Here's what's not working:
- Main dome and map lights OUT
- Door ajar light on dash OUT
- Red lights in door trim OUT
- Luggage compartment light OUT
- Ring around the key OUT
Clock out - probably unrelated.
I know all of these run on the same circuit. I know it could possibly be the integration relay behind the kick panel.
I DO have working instrument lights, cigar lighter works, blinkers and hazards work etc.
I'm a 50 year old former electrical fitter and have been restoring cars since the 80's, so I'm pretty knowledgeable and handy but have my limits.
I've metered the circuit and it's dead. The 10A fuse under the hood is GOOD but there is no 12v supplying it AT ALL which is obviously the culprit.
The advise I need is how the wiring is physically run from the battery to the fuse in the engine compartment as someone sometime has probably cut into it or badly spliced it..or burnt it or chewed it...whatever!
I've checked all the wiring diagrams I can find and although they show plugs to the kick panel set up none I have are labelled showing me the wire that runs from the battery through the kick panel, back to the fuse and then on to the door switches etc (if that's the way it works?).
I'm thinking I may have to bypass the existing 12v supply and run 12v straight to the fuse even as a way of testing it.
Anyway any input you guys might have would be greatly appreciated!
Cheers
Darren
Replies (1 - 3)
post Aug 7, 2016 - 1:46 PM
Lol at the racers!! What i did on my car to supply 12 is to run a wire from the 100a fuse to the fuse that needed energy with thick wire.
post Aug 7, 2016 - 2:14 PM
Box
Joined Feb 23, '12
From Warrior, AL
I know on fourth gen Maximas there is a transistor on the driver side switch panel that if it goes out(almost always due to interior lighting mods) all the interior lighting stops working, or if the panel is unplugged it'll also kill power to the interior lighting. Could be a similar situation, but I can't say for sure since I don't have a Celica anymore to test said theory. Or you can do like mentioned above and call it a day.
2001 Miata LS 5-speed
post Aug 7, 2016 - 4:22 PM
Daz95
Joined Jul 30, '16
From Australia
QUOTE (njccmd2002 @ Aug 7, 2016 - 2:46 PM) *
Thanks! Hey, how come your wiring doesn't have cuts, electrical tape, wires coming out of it that run nowhere, the smell of fried plastic....?? LOL.
I'm sure the previous owner of mine had the dealer option installed called "ASS-CLOWN"!
Lo-Fi Version Time is now: August 4th, 2026 - 1:57 PM
