Feb 21, 2004 - 3:01 AM
Enthusiast ![]() ![]() ![]() Joined Nov 15, '03 From mississippi Currently Offline Reputation: 0 (0%) |
I am wanting to have built a custom engine for my celica but I am not sure how to go about it. I saw one that a guy had machined, every thing was custom and it was just sick(400hp without turbo or NOS) I want something similar but like I said I don't where to start or the cost, can anyone help???
William |
Feb 21, 2004 - 1:03 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
the most powerful A series n\a engine I've seen is the TRD formula 4age's. They run about 240hp I think. How did they do it? COMPRESSION
Feb 22, 2004 - 3:53 AM
Enthusiast ![]() Joined Feb 12, '04 From Hellburbia Currently Offline Reputation: 0 (0%) |
are you looking to go turbo, or build it up NA style?
Feb 23, 2004 - 1:33 AM
Enthusiast ![]() ![]() Joined Jul 31, '03 From Panama City Beach, FL Currently Offline Reputation: 1 (100%) |
i would say the first thing would be to start saving for a custom stroker kit with custom pistons on custom rods, have everything lightened and balanced, custom grind on the cam shaft, port and polish head with performance valve train. ignition booster, wires, coil, fuel pump, injectors, header, full exhaust, stand alone ems, clutch, flywheel... anything lightweight you can get your hands on, get rid of your a/c and that should give you a pretty good bump in power. i can only guess that this kind of setup with the proper tuning could make 200whp+ and cost around $10,000 to $15,000. that is just my guess, it would be sweet to see but that is a lot of money, and i think i was being generous with the price. good luck though
that is the problem with our cars, if we want to do anything with our stock engines we have to be prepared to have damn near everything custom made or machined beyond recognition. This post has been edited by DustyBurns30: Feb 23, 2004 - 1:35 AM |
Feb 23, 2004 - 1:50 AM
They actually have fairly modest compression levels... I read somewhere about being in the 10-11 range... but I can't say for sure. What actually makes the power... revving. They basically have a fairly modified 4AG head (larger valves, stiffer springs, better ports), built internals (lighter stronger rods, crank, bearings), and very very crazy cams. Add that to their professionally tuned fuel system and ECU... then you got a killer n/a engine. It's actually possible to build one yourself, if you have the money for the parts, but most people don't have the 10-20k or so extra dollars to actually build a real Formula A 4AG... now... with that, there's also the TRD Group A 4AG. It's the engine Takumi has in his hachi roku. It's something along the lines of 255 hp at 11,000 rpms... 20V head... etc, etc... -------------------- "It's ok to be naked girl... I'm an artist!"
Feb 23, 2004 - 5:51 PM
Enthusiast ![]() Joined Feb 11, '04 From columbus, ohio Currently Offline Reputation: 0 (0%) |
that is crazy im bout to drop a 350 in my celica j/k
| Lo-Fi Version | Time is now: August 26th, 2026 - 6:50 PM |
