> 5sfte
post Mar 11, 2017 - 3:56 AM
xxFROZENxx
Joined Nov 13, '06
From AUSTRALIA(MELB)
Quick questions guys.
Can I use a 3rd gen 3sgte ignitor to run my 5sfte motor?
Having abit of ignition problems. Cars keeps cutting off at 5000rpm.
Running haltech ps1000 standalone.
Also installed the newer 5sfe oil pump for the crank sensor. Planning to run ls2 coils.
Hopefully it helps.
post Mar 12, 2017 - 3:19 PM
If you have a Haltech then you should be able to just change some settings for the coil/igniter combo you have. Probably an issue with the dwell being set incorrectly.
post Mar 12, 2017 - 10:59 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
to answer your question, the 3rd gen and 5S use the same ignitor.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: June 9th, 2026 - 5:10 PM
